Page 1 of 2 1 2 LastLast
Results 1 to 12 of 15
Thread: CEN Standards Collection 87/370: CEN TC 156 - Ventilation For Buildings
    full list:
    EN 1505:1997 Ventilation for buildings - Sheet metal air ducts and fittings with rectangular cross section - Dimensions
    EN 1506:2007 Ventilation for buildings - Sheet metal air ducts and fittings with circular cross-section - Dimensions
    EN 1507:2006 Ventilation for buildings - Sheet metal air ducts with rectangular section - Requirements for strength and leakage
    EN 1751:2014 Ventilation for buildings - Air terminal devices - Aerodynamic testing of damper and valves
    CR 1752:1998 Ventilation for buildings - Design criteria for the indoor environment
    EN 1886:2007 Ventilation for buildings - Air handling units - Mechanical performance
    EN ISO 5801:2008 Industrial fans - Performance testing using standardized airways (ISO 5801:2007 including Cor 1:2008)
    EN ISO 5802:2008 Industrial fans - Performance testing in situ (ISO 5802:2001)
    EN ISO 5802:2008/A1:2015 Industrial fans - Performance testing in situ (ISO 5802:2001/Amd 1:2015)
    EN 12097:2006 Ventilation for Buildings - Ductwork - Requirements for ductwork components to facilitate maintenance of ductwork systems
    EN 12220:1998 Ventilation for buildings - Ductwork - Dimensions of circular flanges for general ventilation
    EN 12236:2002 Ventilation for buildings - Ductwork hangers and supports - Requirements for strength
    EN 12237:2003 Ventilation for buildings - Ductwork - Strength and leakage of circular sheet metal ducts
    EN 12238:2001 Ventilation for buildings - Air terminal devices - Aerodynamic testing and rating for mixed flow application
    EN 12239:2001 Ventilation for buildings - Air terminal devices - Aerodynamic testing and rating for displacement flow applications
    EN ISO 12499:2008 Industrial fans - Mechanical safety of fans - Guarding (ISO 12499:1999)
    EN 12589:2001 Ventilation for buildings - Air terminal units - Aerodynamic testing and rating of constant and variable rate terminal units
    EN 12599:2012 Ventilation for buildings - Test procedures and measurement methods to hand over air conditioning and ventilation systems
    EN ISO 12759:2015 Fans - Efficiency classification for fans (ISO 12759:2010, including Amd 1:2013)
    EN 12792:2003 Ventilation for buildings - Symbols, terminology and graphical symbols
    EN 13030:2001 Ventilation for buildings - Terminals - Performance testing of louvres subjected to simulated rain
    EN 13053:2006+A1:2011 Ventilation for buildings - Air handling units - Rating and performance for units, components and sections
    EN 13141-1:2004 Ventilation for buildings - Performance testing of components/products for residential ventilation - Part 1: Externally and internally mounted air transfer devices
    EN 13141-2:2010 Ventilation for buildings - Performance testing of components/products for residential ventilation - Part 2: Exhaust and supply air terminal devices
    EN 13141-3:2004 Ventilation for buildings - Performance testing of components/products for residential ventilation - Part 3: Range hoods for residential use
    EN 13141-4:2011 Ventilation for buildings - Performance testing of components/products for residential ventilation - Part 4: Fans used in residential ventilation systems
    EN 13141-5:2004 Ventilation for buildings - Performance testing of components/products for residential ventilation - Part 5: Cowls and roof outlet terminal devices
    EN 13141-6:2014 Ventilation for buildings - Performance testing of components/products for residential ventilation - Part 6: Exhaust ventilation system packages used in a single dwelling
    EN 13141-7:2010 Ventilation for buildings - Performance testing of components/products for residential ventilation - Part 7: Performance testing of a mechanical supply and exhaust ventilation units (including heat recovery) for mechanical ventilation systems intended for
    EN 13141-8:2014 Ventilation for buildings - Performance testing of components/products for residential ventilation - Part 8: Performance testing of un-ducted mechanical supply and exhaust ventilation units (including heat recovery) for mechanical ventilation systems inte
    EN 13141-9:2008 Ventilation for buildings - Performance testing of components/products for residential ventilation - Part 9: Externally mounted humidity controlled air transfer device
    EN 13141-10:2008 Ventilation for buildings - Performance testing of components/products for residential ventilation - Part 10: Humidity controlled extract air terminal device
    EN 13141-11:2015 Ventilation for buildings - Performance testing of components/products for residential ventilation - Part 11: Supply ventilation units
    EN 13142:2013 Ventilation for buildings - Components/products for residential ventilation - Required and optional performance characteristics
    EN 13180:2001 Ventilation for buildings - Ductwork - Dimensions and mechanical requirements for flexible ducts
    EN 13181:2001 Ventilation for buildings - Terminals - Performance testing of louvres subject to simulated sand
    EN 13182:2002 Ventilation for buildings - Instrumentation requirements for air velocity measurements in ventilated spaces
    EN 13182:2002/AC:2002 Ventilation for buildings - Instrumentation requirements for air velocity measurements in ventilated spaces
    EN 13264:2001 Ventilation for buildings - Floor mounted air terminal devices - Tests for structural classification
    EN ISO 13349:2010 Fans - Vocabulary and definitions of categories (ISO 13349:2010)
    EN ISO 13350:2015 Fans - Performance testing of jet fans (ISO 13350:2015)
    EN ISO 13351:2009 Fans - Dimensions (ISO 13351:2009)
    EN 13403:2003 Ventilation for buildings - Non-metallic ducts - Ductwork made from insulation ductboards
    EN 13779:2007 Ventilation for non-residential buildings - Performance requirements for ventilation and room-conditioning systems
    EN 14134:2004 Ventilation for buildings - Performance testing and installation checks of residential ventilation systems
    EN 14239:2004 Ventilation for buildings - Ductwork - Measurement of ductwork surface area
    EN 14240:2004 Ventilation for buildings - Chilled ceilings - Testing and rating
    EN 14277:2006 Ventilation for buildings - Air terminal devices - Method for airflow measurement by calibrated sensors in or close to ATD/plenum boxes
    CR 14378:2002 Ventilation for buildings - Experimental determination of mechanical energy loss coefficients of air handling components
    CR 14378:2002/AC:2002 Ventilation for buildings - Experimental determination of mechanical energy loss coefficients of air handling components
    EN 14518:2005 Ventilation for buildings - Chilled beams - Testing and rating of passive chilled beams
    CEN/TR 14788:2006 Ventilation for buildings - Design and dimensioning of residential ventilation systems
    EN 15116:2008 Ventilation in buildings - Chilled beams - Testing and rating of active chilled beams
    EN 15239:2007 Ventilation for buildings - Energy performance of buildings - Guidelines for inspection of ventilation systems
    EN 15240:2007 Ventilation for buildings - Energy performance of buildings - Guidelines for inspection of air-conditioning systems
    EN 15241:2007 Ventilation for buildings - Calculation methods for energy losses due to ventilation and infiltration in commercial buildings
    EN 15241:2007/AC:2011 Ventilation for buildings - Calculation methods for energy losses due to ventilation and infiltration in buildings
    EN 15242:2007 Ventilation for buildings - Calculation methods for the determination of air flow rates in buildings including infiltration
    EN 15243:2007 Ventilation for buildings - Calculation of room temperatures and of load and energy for buildings with room conditioning systems
    EN 15251:2007 Indoor environmental input parameters for design and assessment of energy performance of buildings addressing indoor air quality, thermal environment, lighting and acoustics
    EN 15423:2008 Ventilation for buildings - Fire precautions for air distribution systems in buildings
    EN 15650:2010 Ventilation for buildings - Fire dampers
    EN 15665:2009 Ventilation for buildings - Determining performance criteria for residential ventilation systems
    EN 15726:2011 Ventilation for buildings - Air diffusion - Measurements in the occupied zone of air-conditioned/ventilated rooms to evaluate thermal and acoustic conditions
    EN 15727:2010 Ventilation for buildings - Ducts and ductwork components, leakage classification and testing
    EN 15780:2011 Ventilation for buildings - Ductwork - Cleanliness of ventilation systems
    EN 16211:2015 Ventilation for buildings - Measurement of air flows on site - Methods
    EN 16445:2013 Ventilation for buildings - Air diffusion - Aerodynamic testing and rating for mixed flow application: non-isothermal procedure for cold jet
    missing:
    EN ISO 5802:2008/A1:2015 Industrial fans - Performance testing in situ (ISO 5802:2001/Amd 1:2015) - missing Amd 1
    EN 13141-6:2014 Ventilation for buildings - Performance testing of components/products for residential ventilation - Part 6: Exhaust ventilation system packages used in a single dwelling - missing valid edition
    EN ISO 13350:2015 Fans - Performance testing of jet fans (ISO 13350:2015) - missing valid edition
    [link Point to another website Only the registered members can access] or
    Re: CEN standards collection 87/100: CEN TC 156 - Ventilation For Buildings
    Really it is a great effort
    Many thanks bro
    Thanks guys!
    Re: CEN Standards Collection 87/300: CEN TC 156 - Ventilation For Buildings
    EN 13141-6:2014 Ventilation for buildings - Performance testing of components/products for residential ventilation - Part 6: Exhaust ventilation system packages used in a single dwelling - better quality
    EN 13141-8:2014 Ventilation for buildings - Performance testing of components/products for residential ventilation - Part 8: Performance testing of un-ducted mechanical supply and exhaust ventilation units (including heat recovery) for mechanical ventilation systems inte - better quality
    EN 13141-11:2015 Ventilation for buildings - Performance testing of components/products for residential ventilation - Part 11: Supply ventilation units - better quality
    EN ISO 13350:2015 Fans - Performance testing of jet fans (ISO 13350:2015) - added missing standard
    EN 16211:2015 Ventilation for buildings - Measurement of air flows on site - Methods - better quality
    now, what's missing is:
    EN ISO 5802:2008/A1:2015 Industrial fans - Performance testing in situ (ISO 5802:2001/Amd 1:2015) - missing A1:2015
    still missing same A1:
    fresh links:
    or
    Aug 2015
    Dubai, UAE
    Blog Entries
    4
    Thanks & Regards:
    Amjad Malik
    thank you my friend...sector complete
    Re: CEN Standards Collection 87/340: CEN TC 156 - Ventilation For Buildings
    update:
    EN ISO 5802:2008 Industrial fans - Performance testing in situ (ISO 5802:2001) - EN version
    sector still complete
    new links:
    or
  11. #9
    Re: CEN Standards Collection 87/370: CEN TC 156 - Ventilation For Buildings
    update:
    added new standards:
    EN 16282-3:2016 Equipment for commercial kitchens - Components for ventilation in commercial kitchens - Part 3: Kitchen ventilation ceilings; design and safety requirements
    EN 16282-4:2016 Equipment for commercial kitchens - Components for ventilation in commercial kitchens - Part 4: Air inlets and outlets; design and safety requirements
    new missing standards are:
    EN 16282-2:2016 Equipment for commercial kitchens - Components for ventilation in commercial kitchens - Part 2: Kitchen ventilation hoods; design and safety requirements
    EN 16753:2017 Ventilation for Buildings - Performance testing of components for residential buildings - Multifunctional balanced ventilation units for single family dwellings* including heat pumps
    new link:
  12. #10
    one of the missing:
    EN 16573:2017 Ventilation for Buildings - Performance testing of components for residential buildings - Multifunctional balanced ventilation units for single family dwellings* including heat pumps
  13. #11
    update:
    better quality or EN versions:
    still missing:
  14.    Spons.
  15. #12
    complete
  1. CEN Standards Collection 181/370: CEN TC 127-Fire Safety In Buildings
    Last Post: 09-27-2018, 10:44 AM
  2. Replies: 6
    Last Post: 12-28-2017, 04:07 PM
  3. Replies: 9
    Last Post: 06-08-2017, 04:43 PM
  4. Replies: 0
    Last Post: 09-25-2016, 10:19 AM
  5. Replies: 0
    Last Post: 08-21-2016, 08:00 AM
