Some few articles and books:
AWS Brazing Handbook - 4th ed.
AWS symbols for brazing, welding....
Microstructural Evolution at the Bonding Interface during the Early-Stage Infrared Active Brazing of Alumina
Brazing of Hot Isostatically Pressed–Al2O3 to Stainless Steel (AISI 304L) by Mo-Mn Route Using 72Ag-28Cu Braze
Joining of AlN with metals and alloys
Bonding of zirconia to super alloy with the active brazing technique
Fabrication and thermal properties of a YSZ–NiCr joint with an interlayer of YSZ–NiCr functionally graded material
Joining of partially sintered alumina to alumina, titanium, Hastealloy and C–SiC composite using Ag–Cu brazes
Joining mechanism in Si3N4 bonded with a Ni–Cr–B interlayer
Effects of Adhesive Composition on Bond Strength of Joined Silicon Nitride Ceramics
The Brazing of S&N4 with Ni-Cr-Si Alloys
Interfacial microstructure of the Si3N4/Si3N4 joint brazed with Cu–Pd–Ti filler alloy
Reactive Brazing Study of a Silicon Nitride to Metal Joining
Joining of Si3N4 to Si3N4 using rapidly-solidified CuNiTiB brazing filler foils
Vacuum brazing of SiO2 glass ceramic and Ti–6Al–4V alloy using AgCuTi filler foil
Mechanical property of induction brazing TiAl-based intermetallics to steel 35CrMo using AgCuTi filler metal
Distribution and Chemistry of PhasesDeveloped in the Brazing of Silicon Nitride to Molybdenum
or
