Page 1 of 2 1 2 LastLast
Results 1 to 12 of 15
Thread: CEN Standards Collection 11/370: EC ISS TC 103: Structural Steels Other Than Rei...
    100% valid standards here... consists of:
    EN 10024:1995 Hot rolled taper flange I sections - Tolerances on shape and dimensions
    EN 10025-1:2004 Hot rolled products of structural steels - Part 1: General technical delivery conditions
    EN 10025-2:2004 Hot rolled products of structural steels - Part 2: Technical delivery conditions for non-alloy structural steels
    EN 10025-2:2004/AC:2005 Hot rolled products of structural steels - Part 2: Technical delivery conditions for non-alloy structural steels
    EN 10025-3:2004 Hot rolled products of structural steels - Part 3: Technical delivery conditions for normalized/normalized rolled weldable fine grain structural steels
    EN 10025-4:2004 Hot rolled products of structural steels - Part 4: Technical delivery conditions for thermomechanical rolled weldable fine grain structural steels
    EN 10025-5:2004 Hot rolled products of structural steels - Part 5: Technical delivery conditions for structural steels with improved atmospheric corrosion resistance
    EN 10025-6:2004+A1:2009 Hot rolled products of structural steels - Part 6: Technical delivery conditions for flat products of high yield strength structural steels in the quenched and tempered condition
    EN 10029:2010 Hot-rolled steel plates 3 mm thick or above - Tolerances on dimensions and shape
    EN 10034:1993 Structural steel I and H sections - Tolerances on shape and dimensions
    EN 10051:2010 Continuously hot-rolled strip and plate/sheet cut from wide strip of non-alloy and alloy steels - Tolerances on dimensions and shape
    EN 10055:1995 Hot rolled steel equal flange tees with radiused root and toes - Dimensions and tolerances on shape and dimensions
    EN 10056-1:1998 Structural steel equal and unequal leg angles - Part 1: Dimensions
    EN 10056-2:1993 Structural steel equal and unequal leg angles - Part 2: Tolerances on shape and dimensions
    EN 10058:2003 Hot rolled flat steel bars for general purposes - Dimensions and tolerances on shape and dimensions
    EN 10059:2003 Hot rolled square steel bars for general purposes - Dimensions and tolerances on shape and dimensions
    EN 10060:2003 Hot rolled round steel bars for general purposes - Dimensions and tolerances on shape and dimensions
    EN 10061:2003 Hot rolled hexagon steel bars for general purposes - Dimensions and tolerances on shape and dimensions
    EN 10067:1996 Hot rolled bulb flats - Dimensions and tolerances on shape, dimensions and mass
    EN 10092-1:2003 Hot rolled spring steel flat bars - Part 1: Flat bars - Dimensions and tolerances on shape and dimensions
    EN 10092-2:2003 Hot rolled spring steel flat bars - Part 2: Ribbed and grooved spring leaves - Dimensions and tolerances on shape and dimensions
    EN 10149-1:2013 Hot rolled flat products made of high yield strength steels for cold forming - Part 1: General technical delivery conditions
    EN 10149-2:2013 Hot rolled flat products made of high yield strength steels for cold forming - Part 2: Technical delivery conditions for thermomechanically rolled steels
    EN 10149-3:2013 Hot rolled flat products made of high yield strength steels for cold forming - Part 3: Technical delivery conditions for normalized or normalized rolled steels
    EN 10163-1:2004 Delivery requirements for surface condition of hot-rolled steel plates, wide flats and sections - Part 1: General requirements
    EN 10163-1:2004/AC:2007 Delivery requirements for surface condition of hot-rolled steel plates, wide flats and sections - Part 1: General requirements
    EN 10163-2:2004 Delivery requirements for surface condition of hot-rolled steel plates, wide flats and sections - Part 2: Plate and wide flats
    EN 10163-3:2004 Delivery requirements for surface condition of hot-rolled steel plates, wide flats and sections - Part 3: Sections
    EN 10164:2004 Steel products with improved deformation properties perpendicular to the surface of the product - Technical delivery conditions
    EN 10210-1:2006 Hot finished structural hollow sections of non-alloy and fine grain steels - Part 1: Technical delivery conditions
    EN 10210-2:2006 Hot finished structural hollow sections of non-alloy and fine grain steels - Part 2: Tolerances, dimensions and sectional properties
    EN 10210-2:2006/AC:2007 Hot finished structural hollow sections of non-alloy and fine grain steels - Part 2: Tolerances, dimensions and sectional properties
    EN 10219-1:2006 Cold formed welded structural hollow sections of non-alloy and fine grain steels - Part 1: Technical delivery conditions
    EN 10219-2:2006 Cold formed welded structural hollow sections of non-alloy and fine grain steels - Part 2: Tolerances, dimensions and sectional properties
    EN 10225:2009 Weldable structural steels for fixed offshore structures - Technical delivery conditions
    EN 10238:2009 Automatically blast-cleaned and automatically prefabrication primed structural steel products
    EN 10248-1:1995 Hot rolled sheet piling of non alloy steels - Part 1: Technical delivery conditions
    EN 10248-2:1995 Hot rolled sheet piling of non alloy steels - Part 2: Tolerances on shape and dimensions
    EN 10249-1:1995 Cold formed sheet piling of non alloy steels - Part 1: Technical delivery conditions
    EN 10249-2:1995 Cold formed sheet piling of non alloy steels - Part 2: Tolerances on shape and dimensions
    EN 10279:2000 Hot rolled steel channels - Tolerances on shape, dimensions and mass
    CEN/TR 10347:2006 Guidance for forming of structural steels in processing
    hugefiles & mediafire links:
    Re: CEN standars collection 11/100: EC ISS TC 103: Structural Steels Other Than Rei..
    a lot of standards are now with better quality, and some GER versions replaced by EN versions
    new links:
    [link Point to another website Only the registered members can access] or
    new links:
    Re: CEN Standards Collection 11/300: EC ISS TC 103: Structural Steels Other Than Rei.
    update:
    EN 10034:1993 Structural steel I and H sections - Tolerances on shape and dimensions - better quality
    new linkz:
    Can you please reupload this on to Mediafire?
    fresh links:
    or
  11. #9
    Re: CEN Standards Collection 11/340: EC ISS TC 103: Structural Steels Other Than Rei.
    nothing changed, fresh links:
    or
  12. #10
    they have released new standard, so it's the one which is missing:
    EN 10363:2016 Continuously hot-rolled patterned steel strip and plate/sheet cut from wide strip - Tolerances on dimensions and shape
    new links:
    or
  13. #11
    Re: CEN Standards Collection 11/350: EC ISS TC 103: Structural Steels Other Than Rei.
    update:
    EN 10363:2016 Continuously hot-rolled patterned steel strip and plate/sheet cut from wide strip - Tolerances on dimensions and shape - added missing standard
    sector complete
    links:
    or
  14.    Spons.
  15. #12
    Re: CEN Standards Collection 11/370: EC ISS TC 103: Structural Steels Other Than Rei.
    update....added new:
    EN 10056-1:2017 Structural steel equal and unequal leg angles - Part 1: Dimensions
    and 1 new is missing:
    EN 10635:2017 Hot rolled steel channels* I and H sections - Dimensions and masses
    new link:
  1. Replies: 30
    Last Post: 07-26-2019, 02:19 PM
  2. CEN standards collection 39/370: Structural Bearings - CEN TC 67
    Last Post: 11-21-2017, 11:28 PM
  3. CEN Standards Collection 23/370: CEN TC 250 - Structural Eurocodes
    Last Post: 11-21-2017, 12:58 AM
  4. Replies: 19
    Last Post: 11-19-2017, 08:53 PM
  5. Replies: 4
    Last Post: 07-11-2017, 08:52 AM
