Results 1 to 5 of 5
Thread: join push - fit pipe
  1. Red face join push - fit pipe
    Hello
    I want know
    If we use grease or oil to lubricate push fit pipe or fitting for connect its
    may be create problem for seal it or clash with spec. or standard
    Thanks.
    Re: join push - fit pipe
    You can use a PTFE grease or a sanitary grease. See the manufacturer and designer spec's.
    Follow the push-on procedure to avoid sealing troubles.
  4. Re: join push - fit pipe
    Quote Originally Posted by JUANPE View Post
    thank you for your respond but we use grease or oil and a person says this lubricant is not suitable for o-ring ( in push fit pipe ) I want to know is it correct or no ?
  5. Red face Re: join push - fit pipe
    Post Re: join push - fit pipe
  1. join to us
    By engmkm in forum Jobs
    Last Post: 04-29-2010, 05:05 PM
