Page 1 of 11 1 2 3 ... LastLast
Results 1 to 12 of 122
Thread: SKM POWER TOOLS - 7.0.2.4 (Working in Windows 8, 64 Bits)
    Nov 2010
    Sweden
    Hi Engineering Community!!!!
    I have running SKM POWER TOOLS - 7.0.2.4 in Windows 8 64 Bits. I am not using Virtual Machine. The successful steps are:
    1) Download the installation files and ****** from these links
    2) Install SKM PTW 7.0.2.4.
    3) Copy the files (ckInfo.exe & CrypKey Site Key Generator.ckInfo) and Paste on C:/……../bin/
    4) Run PTW32 as administrator and install with softkeys ... later you will see your SITE CODE. Later we will use the SIDE CODE
    5) Run ckinfo.exe. as administrator
    6) Select CrypKey Site Key Generator.ckInfo and Open it
    7) Type your SITE CODE and then ENTER... This script will generate your SITE KEY
    8) Copy the Encrypting Key and Paste in your SITE KEY
    9) Click Update. When you click on update you will see these windows. See the picture attached.
    10) Open the "PTW Registry Cleanup UtilIty" and select the option " ALL settings in the registry for PTW" then click OK.
    After you clean the registry you can use the SKM PTW in windows 8 64 Bits. Have fun and share with more people!
    POST DATA: I need the ****** for ETAP 12.6 Who can help me? In the same folder of 4shared you can download more information like ETAP 12.6 (installation files) and more electrical documents check it
    Re: SKM POWER TOOLS - 7.0.2.4 (Working in Windows 8, 64 Bits)
    Thank you friend - it work for me now.
    Nov 2010
    Sweden
    Great ... Let me know if you find the ****** for ETAP 12.6
  5. Re: SKM POWER TOOLS - 7.0.2.4 (Working in Windows 8, 64 Bits)
    Quote Originally Posted by raz View Post
    Dear Sir,
    I cannot find the ******. Would it be possible to post to ****** again? because i really need it. website not foound. Pleasse.....
  6. Re: SKM POWER TOOLS - 7.0.2.4 (Working in Windows 8* 64 Bits)
    SKM Power Tools V8 is out. Could someone please open a new thread for it.
    Please, not found ******......
    Quote Originally Posted by vlady34 View Post
    maybe it was deleted by your AV. Please check your AV (detected items or deleted items). I suggest that instead or uploading rar or zip files, it is may better to be in ISO format.. If you mount it on virtual drive, the AV can't delete them.
    Nov 2010
    Sweden
    Vladimir check again the folders
  11. #9
    Good morning, what happens the ****** does not come in the rar file, so my AV did not eliminate it. I'll check the folder again. Thank You .....
    PD: Not if you have different name but I still find it ....
  12. #10
    Nov 2010
    Sweden
    I made a double check today and all information needed is in the folder.
  13. Re: SKM POWER TOOLS - 7.0.2.4 (Working in Windows 8, 64 Bits)
    It seems that the ****** is not in the folder. Would it be possible to post to ****** again.
    Thanks,
  14.    Spons.
  15. #12
    Nov 2010
    Sweden
    Quote Originally Posted by EE_Newbie View Post
    Thanks,
    Check again the ****** is inside
  1. SKM Power Tools for Windows v7.0 Tutorials
    By Ayuku in forum Electrical & Power Engineering
    Last Post: 07-28-2025, 03:51 PM
  2. PVelite 2014 + ------ (Working x86 x64 windows 8.1)
    By notachance in forum Mechanical Engineering
    Last Post: 04-14-2018, 07:58 AM
  3. Power Tools for Windows 7 (PTW 7.0)
    By orlyboy in forum Electrical & Power Engineering
    Last Post: 06-10-2013, 10:36 AM
