Thread: PROBLEM: ECLIPSE Tools disabled in ECLIPSE OFFICE
    Dec 2013
    Palawan, Philippines
    I have a problem, I cannot start the simulation (and its variants: flogrid, floviz, pvti etc) using office. But each component (floviz, flogrid, graf etc.) Can be run individually using the Simulation Launcher, and not from the Eclipse office itself. Please help me how to set it up! I am asking for help because I am trying to learn office. Hoping for your reply. Best regards! Please check the image for reference.
    Rhett
    Dec 2008
    Venezuela
    Re: PROBLEM: ECLIPSE Tools disabled in ECLIPSE OFFICE
    I would recomend you to read first the eclipse office tutorial. It is one of the pdf files that can be gotten when you first use the simulation launcher. You have access to eclipse office according the picture you send us. You only has to define a new case and follow the tutorial. Also, once you has the new case, you may import an eclipse file (type DATA), and later run eclipse using eclipse office and later use the other programs.
    First go to FIle and create a new project.
    Then the buttons will be enabled to use it.
    Good luck.
    Dec 2013
    Quote Originally Posted by ALFRE01 View Post
    Good luck.
    Hello Alfre01, I have created a project but unfortunately the programs are still disabled. I need them to work so I can simulate from office itself, since the data is created from office, not .data created by a text editor. Thank you for replying. Please see the image attached. Hoping for your reply.
  1. Eclipse 300 problem
    By Rafster in forum Reservoir
    Last Post: 04-30-2013, 02:11 AM
  2. eclipse convergence problem
    By tinni in forum Reservoir
    Last Post: 06-28-2012, 02:56 AM
