Thread: DNV PHAST risk chemical physical property data
  1. DNV PHAST risk chemical physical property data
    there's only a few chemical physical properties data in DNV PHAST RISK software database,can anyone tell me how to get more other chemical data? for example , kerosene and other pure chemical.
    Thank a lot.
    Re: DNV PHAST risk chemical physical property data
    Quote Originally Posted by shiyulan View Post
    Thank a lot.
    you need to be logged as administrator, then you have access to the entire database
  4. Re: DNV PHAST risk chemical physical property data
    thank your reply ,but even so the database is still very limited.
    Quote Originally Posted by Safeti View Post
  5. Re: DNV PHAST risk chemical physical property data
    You have to create your own material from DNV Material Admin, use at least 4 major chemical base material which known as most kerosine containing material
  1. Need Help for Risk Analysis with DNV's Phast Risk Software
    By Sanjay kumar G R in forum Safety And Environment
    Last Post: 06-16-2014, 10:23 AM
  2. What is the physical significance of the RMS of acceleration data ?
    By mrk.mechanical in forum Mechanical Engineering
    Last Post: 08-05-2013, 06:54 PM
  3. Article: Need Help for Risk Analysis with DNV's Phast Risk Software
    By Sanjay kumar G R in forum Home Articles
    Last Post: 04-10-2012, 07:35 AM
