Page 1 of 2 1 2 LastLast
Results 1 to 12 of 15
Thread: HSR & Petrel
  1. HSR & Petrel
    Dear All
    I extract Acoustic Impedance attribute with .dir extension from Hamson Russel
    my question is:
    How can I import it to Petrel?
    please help me
  2. I am not sure for quite understanding your question. From my point of view, if you extract impedance attributes in 2D profile or in 3D volume via HRS. you can export it using Segy
    (Sgy) format. then you can load it into Petrel by selecting SEG-Y Import with preset paramters in Input file parameters. If you extract impedance in 2D Map, you can export it by using Ascii format like horizon interpretation file format, then you can load it into petrel by choosing 2D interpretation format( a quite few format for that). hope this can give some help.
    Navigate to seismic.dir directory where u will find your required .segy file. load this file to petrel
  5. Import velocity model to petrel
    pls help me. I am a new user of Petrel. I have a velocity model in segy and I can't load this model to velocity domain to Petrel, bcs it's loading only as seismic segy. In result i want to transform time seismic cube to depth domain.
    Thanks.
    Valenssa
  6. you need to blocking both seismic and velocity cube as 3D grid with fine scale and do convertion directly by (depth=velocity*time). cheer
    There is no need to resample velocity cube into the grid. You can use the velocity cube directly for depth conversion of your cube. First click the volume attributes process, then select the depth conversion methods/General depth conversion. Then in the input tab, drop your desired cube for depth conversion and in the parameters tab, drop the velocity cube. That's all you wanted..
  9. Thanks.
    But when I click to conversation it's appeared message that no active velocity model. My velocity cube is as seismic in my project. I created it in other product. How to do that my velocity cube would be as interval velocity in petrel. May be I have to calculate it by other method.
    I have petrel 2008
    and demo data 2007 but when turn on demodata my Lab top restart what is the problem mohammed sileem
  11. Hy, Im i nstalling Petrel 2009.1 but as I have vista business 32-bit the program would not install. Is it possible to pass to 64 bit simply or i have to change computer????
    Another question: i do wish petrel only for learning purpose so for me a petrel 2005 to 2008 is good enough, where i can downlod one of it complete with licence etc,........Anyone of u can help me out? Again even a old petrel is good enough. pleasee, thanks in advance
  12. #10
    Anyone as ******** fr Hampson Russel software....
  13. Valenssa
    you have to change the template petrel uses for the velocity cube ,
    double click in the cube in the input pane , go to the info tab , change template to interval velocity .
    good luck
  14.    Spons.
  15. #12
    Petrel2010
    Yes I have Petrel 2010
    email: olevinsofts@gmail.com
  1. Replies: 35
    Last Post: 03-11-2019, 08:08 PM
  2. Exchange Petrel Seismic to Sim with Petrel RE Course
    By Albertmeine in forum Reservoir
    Last Post: 12-05-2013, 05:52 PM
