Thread: Chemcad Version 6.5.3.6250 new
  1. Chemcad Version 6.5.3.6250 new
    VERSION 6.5.3 RELEASE NOTES
    CHEMCAD New Features and Enhancements
    Added the capability to select the equation to use for regressing pure component data (249)
    Added asynchronous error event notification for VBServer (3575)
    Made the 'flowsheet did not converge' message more visible to users (4454)
    Added stream vertices to XML output (4967)
    Added exception handling for database connection errors (4991)
    Removed confirmation dialogs that appeared when using CHEMCAD as an OPC server (5020)
    CHEMCAD Maintenance
    Corrected an issue with the Particle Size Distribution Specification dialog box (1698)
    Corrected an issue where new subcooled delta T values could not be used when "Reload Column Profile" was selected (4813)
    CC-THERM
    Added new functionality to baffle specification for shell-and-tube heat exchangers (56)
    Added the capability to designate baffle spacing on a centerline basis (2268)
    Corrected an issue where importing a CHEMCAD 5 simulation into CHEMCAD 6.5 could alter the number of tubesheets and cause a nonconvergence error (5046)
    CC-DYNAMICS
    Corrected an issue where negative flow in a cut stream prevented the flowsheet from converging (4752)
    Who has the new version and license generator?
    Re: Chemcad Version 6.5.3.6250 new
    yes no new ver after 6.1
    where are links.
    Muhammad Khurram
  1. Chemcad 6.5 latest version
    By kill2000 in forum Computer & Internet
    Last Post: 01-21-2015, 06:40 PM
  2. Htri latest version or old working version
    By devildare013 in forum Oil And Gas Process
    Last Post: 03-14-2014, 02:48 PM
