Results 1 to 10 of 10
Thread: installation of etap6 and etap7
  1. installation of etap6 and etap7
    Hello
    I have downloaded etap6 and etap7 full modules and serial activation. I have a desktop intel core i3 windows xp system and I followed the procedure as provided to install but failed to activate the etap please help.
    Thanks in advance
    Re: installation of etap6 and etap7
    please explain step by step your activation procedure in order to help best to solve the problem
  4. Re: installation of etap6 and etap7
    1. Downloaded ETAP-7 BUT IT DIDNT CONTAINED PETA7 so I downloaded Peta6 from 4shared.com
    2. Disable connection to internet
    3. Disable antivirus software on your computer
    4. Unzipped and burned on DVD
    5. Run Etap-7 installation from DVD.
    6. select install + license manager, just follow the instruction.
    7. finished installation, and closed the apllication
    8. Opened folder LMSETUP\SYSTEM32\DRIVERS on etap DVD
    9. copied all files in the LMSETUP\SYSTEM32\DRIVERS ----- to ------ C:\Windows\System32\Drivers\
    10. Extracted Peta-6 to C\WINDOWS\ETAP007 then run file " etap6.exe "
    9. After finish install --------, then Rebooted computer.
    10. Enable again your antivirus
    11. Run ETAp 7 application.
    BUT IT FAILED to bypass the license manager
    Second method
    9. Unzip file ETAP_5_Demo_-----.rar
    10. Go to your installed Etap folder (C:\etap 700) and locate file 'etapsdb.dll'.
    11. Cut it and paste it in a safe folder (or make a copy). You will need it back later.
    12. Copy the 'etapsdb.dll' file from ETAP_Demo_-----.rar into the Etap installed folder (C:\etap 700).
    13. Run Etap and you will get an error. ETAP will close.
    14. Now copy back the original 'etapsdb.dll' back to your Etap 600 folder and replace the existing one.
    15. Run again Etap. It should ask for the serial number. Enter serial number given in step 7 above.
    THIS METHOD ALSO FAILED
    Please help me SIR
    Operating system?
  6. Re: installation of etap6 and etap7
    Quote Originally Posted by br1x View Post
    Operating system?
    windows xp 32bit (desktop
  8. Re: installation of etap6 and etap7
    Sir i have windows xp 32bit (desktop system)
    Quote Originally Posted by srambiger View Post
    OK,
    read the answer between bracket
    (Peta6 is sufficient)
    (is not necessary)
    (is not necessary)
    (good)
    (good)
    (good)
    (good)
    (bad)
    (bad)
    (good, henceforth is no longer necessary)
    (good)
    (oK)
    (UNINSTALL ETAP AND REINSTALL)
    (12. TYPE THE REG NUMBER)
    where are links for etap
    Muhammad Khurram
  11. Re: installation of etap6 and etap7
    Do I need to uninstall both ETAP.7 and ETAP.7 LICENSE MANAGER and reinstall.. ? I tried uninstall and reinstall of ETAP.7 only but FAILED
    the license manager can not be bypassed................
  12. Re: installation of etap6 and etap7
    I think the problem is in my computer. I successfully installed and activated etap on other computer by doing above said procedure.My os preventing the peta6 execution. How can i solve this
