Thread: Composition of mixture
    Question Composition of mixture
    I have the proprieties (flow rate, composition…) of the oil, gas and water sparatly.
    I need to know how to determine the composition of the mixture (oil, gas and water)?
    Please help me.
    Re: Composition of mixture
    your request is not clear,
    I assume you know the inlet compositions of gas, liquid and water streams and then you wish to calculate the mixed compositions,
    if that is true you need to solve a phase equilibria, see for example
    'http://www.egpet.net/vb/threads/27092-Excel-library-for-process-calc-s-including-distillation'
    Thumbs up Re: Composition of mixture
    Thank you very much.
    I will check
    I hope that i will solve my problem
    Thanks again
  5. Re: Composition of mixture
    You have flowrate, composition...You can mix together by hysys. Output is result you need.
  1. Calculate composition of gas mixture
    By partiapressure in forum Laboratory Measurements
    Last Post: 03-02-2014, 07:11 AM
  2. Article: Calculate composition of gas mixture
    By partiapressure in forum Home Articles
    Last Post: 02-17-2014, 12:26 AM
