Results 1 to 9 of 9
Thread: Scal validation
    Scal validation
    hello,
    can some one give simple and straight forward practical step on how to validate a SCAL report. i read many theoretical info. i need practical ones.
    Jan 2009
    ALA, KZ
    Re: Scal validation
    It is like to advise something on nothing
    What do you want to validate ???
    Re: Scal validation
    Hello temr,
    I need to validate lab data of O-W relative permeability data, and capillary pressure data.
    Jan 2009
    ALA, KZ
    Re: Scal validation
    So for sumulation purposes you will need 2 main thing
    1 is sw vs cap pressure this normally uses in simulation to model saturation and transition zone
    2 you will need to validate end points Swi and Sor vs poro or perm and Krwo Krow exponents , also Krowmax at Sw and Krwomax at Sor
    3 the same thing for gas if you have 3 phase system
    So i gave you guidelines now i would advise to read this topics in more detail
    Use eclipse manual SCAL section
    Re: Scal validation
    Unless there is a major mistake, you usually cannot validate laboratory data. If it is possible you can request lab crude datta and check them for inconsistencies (leaks on the rig, abnormal pressures etc) but this requires a good understanding of rig setup and the volumes.
    Checking their data against eclipse usually does not bring anything. Laboratory crude data is feed into simulator and the curves are produced. Eclipse will not detect anything wrong with them, although they might be totally bullshit. As smd has said: shit in <-> shit out.
    Jan 2009
    ALA, KZ
    Re: Scal validation
    Will agree with Yengineer
    Re: Scal validation
    Thank you temr, and yengineer. Thank you for your help!
    Re: Scal validation
    I'll add some simple checks on SCAL data prior to use this information in Eclipse, or other numerical simulators:
    1. Check the base permeability of the Kr lab-data (usually Ko @ Swir). Most of the times, however, you'll need to input Kr data into the simulator using absolute permeability (Kabs) as the base permeability.
    2. Smooth the Kr curves to prevent convergence-problems, these are associated with sudden changes in the slopes of the kr curves.
    2. When 3-phase calculation is active in Eclipse (or other numerical simulators) this conditions must be satisfied: Krow @ Swir = Krog @ (Sg=0). Eclipse checks that this conditions is satisfied, if not, you'll get a problem.
  11. #9
    Re: Scal validation
    a simple and straight forward rule of thumb:
    plot your points Kro, Krw vs saturation on a linear scale and semi-log scal too
    => the the trend should be concave upwards and smooth (no strange spots) for linear scale (as the theoritical shape let's say)
    => the same thing applies for semi-log plot (the only diffrence is the direction of the shape - concave downwards)
    those are the simple points I do remember from SCAL course I did with Stiles...obviously a thorough QC should be taken.
  1. SCAL simulatord
    By farhan23ali in forum Laboratory Measurements
    Last Post: 06-04-2013, 02:22 PM
  2. SCAL Question?
    By petengr in forum Reservoir
    Last Post: 06-25-2012, 08:32 PM
  3. SCAL software
    By reservoir_engineer in forum Reservoir
    Last Post: 06-05-2012, 05:30 PM
