Thread: What's the difference of tower,column,vessel,tank and drum?Pls give the defination.
  2. Re: What's the difference of tower,column,vessel,tank and drum?Pls give the definatio
    I try to put it a bit simple .we can categorize them either process wise or pressure wise which one suits you .
    Process wise : that depends on the functionality of each item as per process description of the plant for instance pressure vessel,tower and column are used as reactors while tanks and drums used as storage of feedstock or final product .
    Pressure wise : vessels,towers,columns and tanks are considered as pressure equipment. Drums is categorized as non-pressure equipment as well as atmospheric storage tanks.
    P.S column and tower are synonyms.
  1. what‘s the difference between degasser and deaerator?
    By wjw_1980 in forum Oil And Gas Process
    Last Post: 10-13-2013, 11:18 AM
  2. Replies: 1
    Last Post: 09-07-2012, 09:01 PM
  3. Distillation column/vertical vessel design calculations
    By kishor in forum Engineering Spreadsheets & Presentations
    Last Post: 09-23-2010, 08:39 PM
  4. Dear ALi Flare K.O. drum and Seal drum sizing
    By buterfly385 in forum Oil And Gas Process
    Last Post: 06-11-2010, 12:43 PM
