The vapor pressure of a liquid is defined as the pressure exerted by the molecules that escapes from the liquid to form a separate vapor phase above the liquid surface.
The pressure exerted by the vapor phase is called the
- vapor or saturation pressure
Vapor or saturation pressure depends on temperature.
If a fluid consist of more than one component (a solution), components with
- higher vapor pressure are called light components
- lower vapor pressure are called heavy components
[h=Temperature and Vapor or Saturation Pressure for some common Fluids]3[/h] At atmospheric pressure saturation temperature of
- water : 100oC
- ethyl alcohol : 78.5oC
