Thread: Pressure test duration time of valves
  1. Cool Pressure test duration time of valves
    Almost codes related valves such as ASME B16.34, MSS SP-61, API 598, EN 12266, ISO 5208, ISO 17292, etc describe procedure of the pressure test of valves.
    Duration time of the pressure test is decided minimum 180 seconds in above codes.
    But I think minimum 180 seconds is too short to check the durability and quality of the welding of valves in comparison to pressure vessels.
    So, I think it is right that the minimum duration time of valves should be 30 minutes.
    Let me know why the minimum duration time of valves is too short.
    And, If there is long minimum duration time decided in any codes, plz let me know.
    Thanks.
    You should refer to API6D which is the main reference for valve standards.
    there are two major test procedure for valves:
    Shell Test and Seat Test.
    Notewithstanding the test durations differe with size, aproximately shell test lasts 30 minutes and seat test 2 or 5 minutes.
    Attached Files Attached Files
  4. I appreciate with that. Thank you.
  1. valves leakage external test
    By saladino in forum Mechanical Engineering
    Last Post: 05-20-2018, 09:32 PM
  2. ASTM A262 - 10 Standard Practices for IGC Test of Valves
    By HIRENRP in forum Instrumentation & Control
    Last Post: 01-27-2016, 11:43 AM
  3. Article: Pressure relief valves and set pressure
    By samabert in forum Home Articles
    Last Post: 01-08-2014, 06:43 PM
  4. Pressure relief valves and set pressure
    By samabert in forum Mechanical Engineering
    Last Post: 12-30-2013, 11:50 AM
  5. Article: Pressure test duration time of valves
    By sevenieh in forum Home Articles
    Last Post: 06-16-2011, 02:12 AM
