Results 1 to 1 of 1
Thread: Hovoy GRE tubing casing and tubing
  1. Hovoy GRE tubing casing and tubing
    Hovoy GRE casing
    Downhole Casing
    Pipe description
    Pressure range -Max to 3000 psi (21MPa)
    Resin: - Aromatic Amine Cured Epoxy
    Reinforcement materials- Fiberglass
    Joining Systems - API 5B 8rd, Threaded and Coupled
    Joint Length: 9.1 meter Nominal, API
    Temperature - Up to 93.3° C (200° F)
    Diameter – 40mm to 200mm
    Fittings - A variety of filament wound API 5B threaded
    Nipples and Couplings
    Features
    Good mechanical and physical performance
    Corrosion control to CO, H S & salt water
    High flow efficiency
    Easily installation
    Excellent Logging Characteristics
    Long service life
    Applications
    Observation well casing
    Disposal or Injection Tubing to depths of 3000meter
    Production Tubing
    Chemical waste disposal
    Open Hole Casing, Zone or to Surface
  1. API Spec for Casing and Tubing
    By gasengineering in forum Oil And Gas Production
    Last Post: 07-02-2018, 07:04 PM
  2. Tubing pressure higher than casing one
    By kochichiro in forum Reservoir
    Last Post: 03-07-2015, 04:51 PM
  3. Casing/Tubing thread check
    By zemanelpincel in forum Drilling And Workover
    Last Post: 10-13-2012, 04:26 PM
  4. Hovoy GRE tubing
    By franklinshih in forum Pipeline And Fluid Flow
    Last Post: 06-20-2011, 06:04 AM
  5. casing while drilling ,coil tubing
    By ahmed abou zena in forum Drilling And Workover
    Last Post: 03-09-2010, 11:40 PM
