Thread: Aspen Energy Analyzer
  1. Aspen Energy Analyzer
    Hi
    Does someone works with Aspen energy analyzer to build Heat Exchanger Networks?
    I need comments about energy analyzer, is it good.....?
    I am trying to work with it, trying to solve some excercices from the books but its hard...
  2. Ok
    no one answers, let's see if I can motivate the audience
    Let's see this simple base case in Aspen Energy Analyzer
    Inlet T(&#186;C) Outlet T(&#186;C) Q(kW) HTC(W/m2&#186;C) STREAM
    270 160 1980 500 1-hot
    220 60 3520 500 2-hot
    50 210 3200 500 3-cold
    160 210 2500 500 4-cold
    And i have utilities (HP steam and cold water)
    250 249 ---- 2500 HP steam
    15 20 ---- 1000 Cooling water
    And choose 1 maximum split (to simplify) in recommend designs and chose 1 maximum design
    Now try to solve.....you will see a warning: a stream exists with negative specific heat please check input data.
    I think it is everything ok with input data... unless something is wrong with HTC, because if i run the same case with default HTC, the Aspen energy analyzer can generate the perfect HEN
    Chem_JR
  4. Dear Chem_JR,
    you're right. as you know, process streams have different temperature but you input the same HTC. Aspen can not understand what you mean.
  1. Article: Aspen Energy Analyzer - help !
    By nguyenvuong621 in forum Home Articles
    Last Post: 05-02-2013, 04:36 AM
