Thread: Heat Exchanger Fabrication Question?
    Jan 2011
    northwest, usa
    In a dilemma about exactly how tubes are stuffed in a multi baffle plate heat exchanger. The half plate baffles are already stitch welded on inside of exchanger pipe.
    With only a 1/64" clearance in holes for tubes I cannot fathom how one would insert a 35 ft tube thru the full length of a pipe with half baffle plates every 8 ft..
    It seems like you would need a broom handle type wood stick aligned thru full length of pipe thru each baffle and then use it as a guide for the tube.
    I don't know, have you had any experience around heat exchanger fabrication?
    Appreciate your comments and advice,
    Robert
    Dont worry, just install tie rods, then it will align the holes.
    now start tube insertion, dont forget to chamfer the tube end.
    if you send drawing or photograph, i will let you know more.
  1. Heat exchanger in platforms above similar Heat exchanger
    By rentecgomez in forum Oil And Gas Production
    Last Post: 05-16-2014, 06:49 AM
  2. Article: Heat Exchanger Fabrication Question?
    By sooeey2u in forum Home Articles
    Last Post: 08-23-2011, 12:45 PM
  3. Article: Heat Exchanger Fabrication Question?
    Last Post: 03-04-2011, 08:36 AM
  4. heat exchanger
    By biswjeet in forum Mechanical Engineering
    Last Post: 06-25-2010, 01:11 PM
