Thread: Performance of Polytropic Compressors
    Compressors are gas movers. It is a mechanical device that increases the pressure of a gas by reducing its volume. Compression of a gas naturally increases its temperature. There are two basic types of compressors: the reciprcating compressor which is well suited for high pressures and low flow rates, and the centrifugal compressor which is preferred for low pressures and high rates.
    Compressors are rated in height of compression head developed. From the point of view of thermodynamics, real compression processes are polytropic processes, which lie somewhat between adiabatic and isothermal compression.
    The polytropic head and discharge temperature are given from the following expressions (from which horsepower can be derived):
    where
    H = polytropic head
    Z = average compressibility factor
    R = universal gas constant
    P1 = suction gas pressure
    P2 = discharge gas pressure
    Rc = compression ratio = P2/P1
    T1 = suction gas temperature
    T2 = discharge gas temperature
    Mw = molecular weight of gas
    n = polytropic exponent = Cp/Cv
    Cp = gas specific heat at constant pressure
    Cv = gas specific heat at constant volume
    BIBLIOGRAPHY
    • Coker, AK; Fortran Programs For Chemical Process Design, Analysis & Simulation; Gulf Publ. Co, Houston, 1995.
    • Chopey, NP; Handbook of Chemical Engineering Calculations; McGraw Hill, New York, 2003.
    Quality education is the best investment for your future,Knowledge is power
    Give me a spot to stand in and i well shake the whole world
    THanksssss
    Feb 2009
    I live in Indonesia
    thanks guy
  5. helpme information required soloarturbines turbocompresors for ejecution gas plant compresors
  1. Reciprocating Compressors
    By TOLGAUS in forum Oil And Gas Process
    Last Post: 03-18-2014, 03:46 PM
  2. Replies: 7
    Last Post: 08-12-2011, 09:44 AM
