Results 1 to 6 of 6
Thread: relative permeability curves - Modified Corey Brooks
    Hello all,
    I have 8 rel perm curves taken from the same well. I'd like to use the modified brooks-corey method to normalize/average the curves.
    Can anyone share a document that has the details of this process?
    best regards,
    Tarik
    Feb 2010
    Tierra
    this is an interesting reading material to help you sort the problem using modified brooks-corey method
    ~ He who seeks, should take a Stride ~
    Nov 2008
    asia pacific
    normalised rel-perms
    I cant think of a specific article - but the steps are as follows assuming krw, kro curves.
    1. modified corey asserts: krw ~ Ew*Swn^Nw , kro ~ Eo*Son^No where Ew, Eo are constants and Nw, No are the constant exponents. Swn Son are "normalised" saturations.
    2. Swn = (Sw-Swir)/(1-Swir-Sorw) , Son = 1-Swn = (So-Sorw)/(1-Swir-Sorw)
    3. Swir is the irreducible water sat. Sorw is the residual oil sat. ( that vary sample by sample)
    4. For each of your samples your need to identify Swir, Sorw ( not as easy as you think - esp Sorw) then calculate the equivalent Swn values in the range [0,1]
    5. Plot all the curves on krw, kro vs Swn * do they look the same ? ( this is where the fun begins) - do you average / discard / bin ??
    6. Some folk normalise the y-axis too per sample Ew'=1=krw/krw_max=krw/Ew and plot krw' , kro' vs Swn ( I tend not to do this as there's more info in Ew than Ew' )
    You will find that ALL lab data need to be corrected - and this is best done by iteratively fitting Nw, No, Sorw via excel until you get a good match. Corelabs report Sorw from the highest Sw achieved - this is usually not the 'real' Sorw. Similary Steady State coreflood produce different Sorw's than Unsteady State and centrifuge tests ( for good reasons). ( I recommend doing this is general - but this wasnt the question you asked). You will notice that I left Swir out - as this variable tends to be "better" defined by lab data .... its usually Sorw that is the focus.
    I've noticed such questions arise time and time again - if you want to send me your raw data - I'll have a look and provide a step solution for the whole group that the admins can make a sticky ( if they want). Take all mention of the reservoir off the data sets.
    My experience is that up to 50% of SCAL data is often "off trend" for various reasons - and the user needs to seach for the "jewell" that are left .... ( leave me a message about how to contact you)
    The steps listed above are fairly easy to do ... but further refinements may help particulary if the 8 data sets come from very different poro-perm sets.
    itag
    From anihitas link you may also find this interesting
    —Big Oil Executive
    Hi Itag,
    Thanks for your valuable contribution. I am interested i doing what u discussed in the forum. Can you send me examples (i.e excel)on this topic. my email ariesbana@gmai.com
  1. Replies: 1
    Last Post: 06-06-2013, 10:19 PM
  2. Relative Permeability Curves !!
    By spydaman in forum Reservoir
    Last Post: 10-05-2012, 10:01 AM
  3. Help needed with Relative permebility Curves
    By khanisar in forum Reservoir
    Last Post: 11-29-2011, 01:33 PM
  4. Relative Permeability Using Corey Model
    By bayan in forum Reservoir
    Last Post: 10-22-2011, 03:55 PM
  5. Relative Permeability Curves MBAL IPM
    By zaheer.jamali in forum Reservoir
    Last Post: 04-02-2011, 06:29 PM
