Originally Posted by
Nasiruddin
Dear Friend,
Amines is one of the best choice for such applications. Better to use mix amine, mixture of MDEA+DEA or MDEA+MEA, first amine should be in small amount in the range of 2-4 wt% only. Use of Glycol depends on downstream processing, if you are going for high LPG recovery using Turbo-expander or Ortloff Process, then Molecular sieve will be used for gas drying, if not then TEG based dehydration system will be good enough to meet desired water dew point specification.
