Thread: open a file( version hysys 2006) with hysys 2004
  1. open a file( version hysys 2006) with hysys 2004
    hello guys
    I need help !!!!!!
    I made a simulation with hysys 2006. how can I save it to open it with the 2004 version !!!!!!
    p.s.sorry for my english
    thanks in advance
  2. Save it to XML format in Aspen Hysys V2006. Then open the XML format file in Aspen Hysys V2004. You should also note that XML files generated in Unisim Hysys may not be openable in Aspen Hysys and vice versa (it will depend on the relevant versions). When you do this exercise (Hysys V2006 to V2004), you may get some corruption of the stream connections on exchangers. You will have to break and reconnect the streams so that they are correctly lined up (hotside and coldside). The graphics may also be a mess and you will have to tidy it up.
  4. Smile
    hello!!!!!!
    It seems to work well
    thank you very much
  1. There is any stand alone version of HYSYS after 2006?
    By huge1000 in forum Oil And Gas Process
    Last Post: 06-22-2013, 01:53 AM
