CEN Standards Collection 208/370: CEN TC 129-Glass In Buidling
full list:
EN 356:1999 Glass in building - Security glazing - Testing and classification of resistance against manual attack
EN 357:2004 Glass in building - Fire resistant glazed elements with transparent or translucent glass products - Classification of fire resistance
EN 410:2011 Glass in building - Determination of luminous and solar characteristics of glazing
EN 572-1:2012+A1:2016 Glass in building - Basic soda-lime silicate glass products - Part 1: Definitions and general physical and mechanical properties
EN 572-2:2012 Glass in building - Basic soda lime silicate glass products - Part 2: Float glass
EN 572-3:2012 Glass in building - Basic soda lime silicate glass products - Part 3: Polished wired glass
EN 572-4:2012 Glass in building - Basic soda lime silicate glass products - Part 4: Drawn sheet glass
EN 572-5:2012 Glass in building - Basic soda lime silicate glass products - Part 5: Patterned glass
EN 572-6:2012 Glass in building - Basic soda lime silicate glass products - Part 6: Wired patterned glass
EN 572-7:2012 Glass in building - Basic soda lime silicate glass products - Part 7: Wired or unwired channel shaped glass
EN 572-8:2012+A1:2016 Glass in building - Basic soda-lime silicate glass products - Part 8: Supplied and final cut sizes
EN 572-9:2004 Glass in building - Basic soda lime silicate glass products - Part 9: Evaluation of conformity/Product standard
EN 673:2011 Glass in building - Determination of thermal transmittance (U value) - Calculation method
EN 674:2011 Glass in building - Determination of thermal transmittance (U value) - Guarded hot plate method
EN 675:2011 Glass in building - Determination of thermal transmittance (U value) - Heat flow meter method
EN 1036-1:2007 Glass in building - Mirrors from silver-coated float glass for internal use - Part 1: Definitions, requirements and test methods
EN 1036-2:2008 Glass in building - Mirrors from silver-coated float glass for internal use - Part 2: Evaluation of conformity; product standard
EN 1051-1:2003 Glass in building - Glass blocks and glass pavers - Part 1: Definitions and description
EN 1051-2:2007 Glass in building - Glass blocks and glass pavers - Part 2: Evaluation of conformity/Product standard
EN 1063:1999 Glass in building - Security glazing - Testing and classification of resistance against bullet attack
EN 1096-1:2012 Glass in building - Coated glass - Part 1: Definitions and classification
EN 1096-2:2012 Glass in building - Coated glass - Part 2: Requirements and test methods for class A, B and S coatings
EN 1096-3:2012 Glass in building - Coated glass - Part 3: Requirements and test methods for class C and D coatings
EN 1096-4:2004 Glass in building - Coated glass - Part 4: Evaluation of conformity/Product standard
EN 1096-5:2016 Glass in building - Coated glass - Part 5 - Test method and classification for the self-cleaning performances of coated glass surfaces
EN 1279-1:2004 Glass in Building - Insulating glass units - Part 1: Generalities, dimensional tolerances and rules for the system description
EN 1279-1:2004/AC:2006 Glass in Building - Insulating glass units - Part 1: Generalities, dimensional tolerances and rules for the system description
EN 1279-2:2002 Glass in building - Insulating glass units - Part 2: Long term test method and requirements for moisture penetration
EN 1279-3:2002 Glass in building - Insulating glass units - Part 3: Long term test method and requirements for gas leakage rate and for gas concentration tolerances
EN 1279-4:2002 Glass in building - Insulating glass units - Part 4: Methods of test for the physical attributes of edge seals
EN 1279-5:2005+A2:2010 Glass in building - Insulating glass units - Part 5: Evaluation of conformity
EN 1279-6:2002 Glass in building - Insulating glass units - Part 6: Factory production control and periodic tests
EN 1288-1:2000 Glass in building - Determination of the bending strength of glass - Part 1: Fundamentals of testing glass
EN 1288-2:2000 Glass in building - Determination of bending strength of glass - Part 2: Coaxial double ring test on flat specimens with large test surface areas
EN 1288-3:2000 Glass in building - Determination of the bending strength of glass - Part 3: Test with specimen supported at two points (four point bending)
EN 1288-4:2000 Glass in building - Determination of the bending strength of glass - Part 4: Testing of channel shaped glass
EN 1288-5:2000 Glass in building - Determination of the bending strength of glass - Part 5: Coaxial double ring test on flat specimens with small test surface areas
EN 1748-1-1:2004 Glass in building - Special basic products -Borosilicate glasses - Part 1-1: Definition and general physical and mechanical properties
EN 1748-1-2:2004 Glass in building - Special basic products - Borosilicate glasses - Part 1-2: Evaluation of conformity/Product standard
EN 1748-2-1:2004 Glass in building - Special basic products - Glass ceramics - Part 2-1 Definitions and general physical and mechanical properties
EN 1748-2-2:2004 Glass in building - Special basic products - Glass ceramics - Part 2-2: Evaluation of conformity/Product standard
EN 1863-1:2011 Glass in building - Heat strengthened soda lime silicate glass - Part 1: Definition and description
EN 1863-2:2004 Glass in building - Heat strengthened soda lime silicate glass - Part 2: Evaluation of conformity/Product standard
EN 12150-1:2015 Glass in building - Thermally toughened soda lime silicate safety glass - Part 1: Definition and description
EN 12150-2:2004 Glass in building - Thermally toughened soda lime silicate safety glass - Part 2: Evaluation of conformity/Product standard
EN 12337-1:2000 Glass in building - Chemically strengthened soda lime silicate glass - Part 1: Definition and description
EN 12337-2:2004 Glass in building - Chemically strengthened soda lime silicate glass - Part 2: Evaluation of conformity/Product standard
EN ISO 12543-1:2011 Glass in building - Laminated glass and laminated safety glass - Part 1: Definitions and description of component parts (ISO 12543-1:2011)
EN ISO 12543-2:2011 Glass in building - Laminated glass and laminated safety glass - Part 2: Laminated safety glass (ISO 12543-2:2011)
EN ISO 12543-3:2011 Glass in building - Laminated glass and laminated safety glass - Part 3: Laminated glass (ISO 12543-3:2011)
EN ISO 12543-4:2011 Glass in building - Laminated glass and laminated safety glass - Part 4: Test methods for durability (ISO 12543-4:2011)
EN ISO 12543-5:2011 Glass in building - Laminated glass and laminated safety glass - Part 5: Dimensions and edge finishing (ISO 12543-5:2011)
EN ISO 12543-6:2011 Glass in building - Laminated glass and laminated safety glass - Part 6: Appearance (ISO 12543-6:2011)
EN ISO 12543-6:2011/AC:2012 Glass in building - Laminated glass and laminated safety glass - Part 6: Appearance (ISO 12543-6:2011)
EN 12600:2002 Glass in building - Pendulum test - Impact test method and classification for flat glass
EN 12603:2002 Glass in building - Procedures for goodness of fit and confidence intervals for Weibull distributed glass strength data
EN 12758:2011 Glass in building - Glazing and airborne sound insulation - Product descriptions and determination of properties
EN 12898:2001 Glass in building - Determination of the emissivity
EN 13022-1:2014 Glass in building - Structural sealant glazing - Part 1: Glass products for structural sealant glazing systems for supported and unsupported monolithic and multiple glazing
EN 13022-2:2014 Glass in building - Structural sealant glazing - Part 2: Assembly rules
EN 13024-1:2011 Glass in building - Thermally toughened borosilicate safety glass - Part 1: Definition and description
EN 13024-2:2004 Glass in building - Thermally toughened borosilicate safety glass - Part 2: Evaluation of conformity/Product standard
EN 13541:2012 Glass in building - Security glazing - Testing and classification of resistance against explosion pressure
EN 14178-1:2004 Glass in building - Basic alkaline earth silicate glass products - Part 1: Float glass
EN 14178-2:2004 Glass in building - Basic alkaline earth silicate glass products - Part 2: Evaluation of conformity/Product standard
EN 14179-1:2005 Glass in building - Heat soaked thermally toughened soda lime silicate safety glass - Part 1: Definition and description
EN 14179-2:2005 Glass in building - Heat soaked thermally toughened soda lime silicate safety glass - Part 2: Evaluation of conformity/Product standard
EN 14321-1:2005 Glass in building - Thermally toughened alkaline earth silicate safety glass - Part 1: Definition and description
EN 14321-2:2005 Glass in building - Thermally toughened alkaline earth silicate safety glass - Part 2: Evaluation of conformity/Product standard
EN ISO 14438:2002 Glass in building - Determination of energy balance value - Calculation method (ISO 14438:2002)
EN 14449:2005 Glass in building - Laminated glass and laminated safety glass - Evaluation of conformity/Product standard
EN 14449:2005/AC:2005 Glass in building - Laminated glass and laminated safety glass - Evaluation of conformity/Product standard
EN 15681-1:2016 Glass in building - Basic alumino silicate glass products - Part 1: Definitions and general physical and mechanical properties
EN 15682-1:2013 Glass in building - Heat soaked thermally toughened alkaline earth silicate safety glass - Part 1: Definition and description
EN 15682-2:2013 Glass in building - Heat soaked thermally toughened alkaline earth silicate safety glass - Part 2: Evaluation of conformity/Product standard
EN 15683-1:2013 Glass in building - Thermally toughened soda lime silicate channel shaped safety glass - Part 1: Definition and description
EN 15683-2:2013 Glass in building - Thermally toughened soda lime silicate channel shaped safety glass - Part 2: Evaluation of conformity/Product standard
EN 15752-1:2014 Glass in building - Adhesive backed polymeric film - Part 1: Definitions and requirements
EN 15755-1:2014 Glass in building - Adhesive backed polymeric filmed glass - Part 1: Definitions and requirements
EN 15998:2010 Glass in building - Safety in case of fire, fire resistance - Glass testing methodology for the purpose of classification
missing:
EN 572-1:2012+A1:2016 Glass in building - Basic soda-lime silicate glass products - Part 1: Definitions and general physical and mechanical properties - missing A1:2016
EN 572-8:2012+A1:2016 Glass in building - Basic soda-lime silicate glass products - Part 8: Supplied and final cut sizes - missing A1:2016
EN 1096-5:2016 Glass in building - Coated glass - Part 5 - Test method and classification for the self-cleaning performances of coated glass surfaces - missing standard
EN 1279-1:2004/AC:2006 Glass in Building - Insulating glass units - Part 1: Generalities, dimensional tolerances and rules for the system description - missing AC:2006
EN 14449:2005/AC:2005 Glass in building - Laminated glass and laminated safety glass - Evaluation of conformity/Product standard - missing AC:2005
EN 15681-1:2016 Glass in building - Basic alumino silicate glass products - Part 1: Definitions and general physical and mechanical properties - missing standard
linkz:
[url]http://hugefiles.net/5tmo6kjcdm0i[/url]
or
[url]http://www.mediafire.com/download/53377ndghe1759n/gib.rar[/url]
Re: CEN Standards Collection 208/300: CEN TC 129-Glass In Buidling
Dear BornToSin,
Please share the following standards sectors please:
a) CEN/CLC/TC2: Power engineering
b) CEN/TC247: Building Automation, Controls & Building management
c) CEN/TC228: Heating systems & Water based cooing systems in buildings
Very good and very useful collection!
Thanks for it.
[QUOTE=virtech1;322029]Dear BornToSin,
c) CEN/TC228: Heating systems & Water based cooing systems in buildings[/QUOTE]
Power engineering is shared and links will be updated later today
for the rest two sectors, just do the advanced search here and you will find the links
update:
EN 15681-1:2016 Glass in building - Basic alumino silicate glass products - Part 1: Definitions and general physical and mechanical properties - added missing standard
missing list:
new links:
[url]http://hugefiles.net/j3zizztby076[/url]
or
[url]http://www.mediafire.com/download/w2zo5y8p4o3o237/glinbu.rar[/url]
Re: CEN Standards Collection 208/340: CEN TC 129-Glass In Buidling
update:
EN 572-1:2012+A1:2016 Glass in building - Basic soda-lime silicate glass products - Part 1: Definitions and general physical and mechanical properties - added missing standard
EN 1096-5:2016 Glass in building - Coated glass - Part 5 - Test method and classification for the self-cleaning performances of coated glass surfaces - added missing standard
missing list:
EN 12488:2016 Glass in building - Glazing recommendations - Assembly principles for vertical and sloping glazing
EN 14179-1:2016 Glass in building - Heat soaked thermally toughened soda lime silicate safety glass - Part 1: Definition and description
links:
[url]http://hugefiles.net/wju59abrbiki[/url]
or
[url]http://www.mediafire.com/download/4461hckot60xkfr/gibuil.rar[/url]
Re: CEN Standards Collection 208/350: CEN TC 129-Glass In Buidling
update:
EN 1279-1:2004/AC:2006 Glass in Building - Insulating glass units - Part 1: Generalities, dimensional tolerances and rules for the system description - added missing AC
missing:
updated links:
or
[url]https://1fichier.com/?wglbqvwihl[/url]
update:
EN 12488:2016 Glass in building - Glazing recommendations - Assembly principles for vertical and sloping glazing - added missing standard
EN 14179-1:2016 Glass in building - Heat soaked thermally toughened soda lime silicate safety glass - Part 1: Definition and description - added missing standard
EN 14449:2005/AC:2005 Glass in building - Laminated glass and laminated safety glass - Evaluation of conformity/Product standard - added missing AC
the only one missing right now is:
new links:
[url]http://www.mediafire.com/file/4461hckot60xkfr/gibuil.rar[/url]
or
[url]https://1fichier.com/?cqzl22df2a[/url]
and the missing standard:
[url]https://1fichier.com/?32452am1ue[/url]
or
[url]http://www.mediafire.com/file/aby22aus5ph83yq/BS_EN_00572-8-2012_A1-2016.pdf[/url]
sector complete
Re: CEN Standards Collection 208/370: CEN TC 129-Glass In Buidling
update:
added new:
EN 15681-2:2017 Glass in Building - Basic alumino silicate glass products - Part 2: Product standard
and new is missing:
EN 16477-1:2016 Glass in building - Painted glass for internal use - Part 1: Requirements
[url]http://www.mediafire.com/file/e9k32zdkqwbc2bd/CEN_208-Glass_In_Building.rar[/url]
update:
better quality:
added missing:
complete
[url]http://www.mediafire.com/file/5d4mbaa5v989ben/CEN_208-Glass_In_Building_%2808-06-2017%29.rar[/url]
Great colection...
I can not open or access the link, could any friend send en 1279 to my email ?mjd29@126.com
Thanks a lot!
