I messed up with this one, so editing post...New post with updated list in link above as soon as it upload finish....1 hour or little bit more
Printable View
hi! i can't access hugefiles.net; need the mediafire link instead.
please kindly provide alternative.
thanks & merry x'mas.
many thanks dear
Here is the real list of this CEN sector...only missing 5 valid editiond:
EN ISO 148-1:2010 Metallic materials - Charpy pendulum impact test - Part 1: Test method (ISO 148-1:2009)
EN ISO 148-2:2008 Metallic materials - Charpy pendulum impact test - Part 2: Verification of testing machines (ISO 148-2:2008)
EN ISO 148-3:2008 Metallic materials - Charpy pendulum impact test - Part 3: Preparation and characterization of Charpy V-notch test pieces for indirect verification of pendulum impact machines (ISO 148-3:2008)
EN ISO 204:2009 Metallic materials - Uniaxial creep testing in tension - Method of test (ISO 204:2009)
EN ISO 376:2011 Metallic materials - Calibration of force-proving instruments used for the verification of uniaxial testing machines (ISO 376:2011)
EN ISO 642:1999 Steel - Hardenability test by end quenching (Jominy test) (ISO 642:1999)
EN ISO 643:2012 Steels - Micrographic determination of the apparent grain size (ISO 643:2012)
EN ISO 2566-1:1999 Steel - Conversion of elongation values - Part 1: Carbon and low alloy steels (ISO 2566-1:1984)
EN ISO 2566-2:1999 Steel - Conversion of elongation values - Part 2: Austenitic steels (ISO 2566-2:1984)
EN ISO 2639:2002 Steels - Determination and verification of the depth of carburized and hardened cases (ISO 2639:2002)
EN ISO 3651-1:1998 Determination of resistance to intergranular corrosion of stainless steels - Part 1: Austenitic and ferritic-austenitic (duplex) stainless steels - Corrosion test in nitric acid medium by measurement of loss in mass (Huey test) (ISO 3651-1:1998)
EN ISO 3651-2:1998 Determination of resistance to intergranular corrosion of stainless steels - Part 2: Ferritic, austenitic and ferritic-austenitic (duplex) stainless steels - Corrosion test in media containing sulfuric acid (ISO 3651-2:1998)
EN ISO 3785:2006 Metallic materials - Designation of test specimen axes in relation to product texture (ISO 3785:2006)
EN ISO 3887:2003 Steels - Determination of depth of decarburization (ISO 3887:2003)
EN ISO 4545-1:2005 Metallic materials - Knoop hardness test - Part 1: Test method (ISO 4545-1:2005)
EN ISO 4545-2:2005 Metallic materials - Knoop hardness test - Part 2: Verification and calibration of testing machines (ISO 4545-2:2005)
EN ISO 4545-3:2005 Metallic materials - Knoop hardness test - Part 3: Calibration of reference blocks (ISO 4545-3:2005)
EN ISO 4545-4:2005 Metallic materials - Knoop hardness test - Part 4: Table of hardness values (ISO 4545-4:2005)
EN ISO 6506-1:2014 Metallic materials - Brinell hardness test - Part 1: Test method (ISO 6506-1:2014)
EN ISO 6506-2:2014 Metallic materials - Brinell hardness test - Part 2: Verification and calibration of testing machines (ISO 6506-2:2014)
EN ISO 6506-3:2014 Metallic materials - Brinell hardness test - Part 3: Calibration of reference blocks (ISO 6506-3:2014)
[I]EN ISO 6506-4:2014 Metallic materials - Brinell hardness test - Part 4: Table of hardness values (ISO 6506-4:2014) - missing VE[/I]
EN ISO 6507-1:2005 Metallic materials - Vickers hardness test - Part 1: Test method (ISO 6507-1:2005)
EN ISO 6507-2:2005 Metallic materials - Vickers hardness test - Part 2: Verification and calibration of testing machines (ISO 6507-2:2005)
EN ISO 6507-3:2005 Metallic materials - Vickers hardness test - Part 3: Calibration of reference blocks (ISO 6507-3:2005)
EN ISO 6507-4:2005 Metallic materials - Vickers hardness test - Part 4: Tables and hardness values (ISO 6507-4:2005)
EN ISO 6508-1:2015 Metallic materials - Rockwell hardness test - Part 1: Test method (scales A, B, C, D, E, F, G, H, K, N, T) (ISO 6508-1:2015)
EN ISO 6508-2:2015 Metallic materials - Rockwell hardness test - Part 2: Verification and calibration of testing machines (scales A, B, C, D, E, F, G, H, K, N, T) (ISO 6508-2:2015)
EN ISO 6508-3:2015 Metallic materials - Rockwell hardness test - Part 3: Calibration of reference blocks (scales A, B, C, D, E, F, G, H, K, N, T) (ISO 6508-3:2015)
EN ISO 6892-1:2009 Metallic materials - Tensile testing - Part 1: Method of test at room temperature (ISO 6892-1:2009)
EN ISO 6892-2:2011 Metallic materials - Tensile testing - Part 2: Method of test at elevated temperature (ISO 6892-2:2011)
EN ISO 6892-3:2015 Metallic materials - Tensile testing - Part 3: Method of test at low temperature (ISO 6892-3:2015)
EN ISO 7438:2005 Metallic materials - Bend test (ISO 7438:2005)
EN ISO 7500-1:2004 Metallic materials - Verification of static uniaxial testing machines - Part 1: Tension/compression testing machines - Verification and calibration of the force-measuring system (ISO 7500-1:2004)
EN ISO 7500-1:2004/AC:2009 Metallic materials - Verification of static uniaxial testing machines - Part 1: Tension/compression testing machines - Verification and calibration of the force-measuring system (ISO 7500-1:2004/Cor 1:2008)
EN ISO 7500-2:2006 Metallic materials - Verification of static uniaxial testing machines - Part 2: Tension creep testing machines - Verification of the applied force (ISO 7500-2:2006)
EN ISO 7799:2000 Metallic materials - Sheet and strip 3 mm thick or less - Reverse bend test (ISO 7799:1985)
EN ISO 9513:2012 Metallic materials - Calibration of extensometer systems used in uniaxial testing (ISO 9513:2012)
EN ISO 9513:2012/AC:2013 Metallic materials - Calibration of extensometer systems used in uniaxial testing - Technical Corrigendum 1 (ISO 9513:2012/Cor 1:2013)
EN ISO 10113: 2014 Metallic materials - Sheet and strip - Determination of plastic strain ratio (ISO 10113:2006, Corrected version 2007-08-01)
EN 10160:1999 Ultrasonic testing of steel flat product of thickness equal or greater than 6 mm (reflection method)
EN 10229:1998 Evaluation of resistance of steel products to hydrogen induced *****ing (HIC)
EN 10247:2007 Micrographic examination of the non-metallic inclusion content of steels using standard pictures
EN ISO 10275:2014 Metallic materials - Sheet and strip - Determination of tensile strain hardening exponent (ISO 10275:2007)
EN 10306:2001 Iron and steel - Ultrasonic testing of H beams with parallel flanges and IPE beams
EN 10307:2001 Non-destructive testing - Ultrasonic testing of austenitic and austenitic-ferritic stainless steels flat products of thickness equal to or greater than 6 mm (reflection method)
EN 10308:2001 Non destructive testing - Ultrasonic testing of steel bars
EN 10319-1:2003 Metallic materials - Tensile stress relaxation testing - Part 1: Procedure for testing machines
EN 10319-2:2006 Metallic materials - Tensile stress relaxation testing - Part 2: Procedure for bolted joint models
EN 10325:2006 Steel - Determination of yield strength increase by the effect of heat treatment [Bake-Hardening-Index]
EN 10328:2005 Iron and steel - Determination of the conventional depth of hardening after surface heating
EN ISO 10113:2014 Metallic materials - Sheet and strip - Determination of plastic strain ratio (ISO 10113:2006)
EN ISO 12004-1:2008 Metallic materials - Sheet and strip - Determination of forming-limit curves - Part 1: Measurement and application of forming-limit diagrams in the press shop (ISO 12004-1:2008)
EN ISO 12004-2:2008 Metallic materials - Sheet and strip - Determination of forming-limit curves - Part 2: Determination of forming-limit curves in the laboratory (ISO 12004-2:2008)
[I]EN ISO 14556:2015 Metallic materials - Charpy V-notch pendulum impact test - Instrumented test method (ISO 14556:2015) - missing VE[/I]
EN ISO 14577-1:2015 Metallic materials - Instrumented indentation test for hardness and materials parameters - Part 1: Test method (ISO 14577-1:2015)
EN ISO 14577-2:2015 Metallic materials - Instrumented indentation test for hardness and materials parameters - Part 2: Verification and calibration of testing machines (ISO 14577-2:2015)
EN ISO 14577-3:2015 Metallic materials - Instrumented indentation test for hardness and materials parameters - Part 3: Calibration of reference blocks (ISO 14577-3:2015)
EN ISO 14577-4:2007 Metallic materials - Instrumented indentation test for hardness and materials parameters - Part 4: Test method for metallic and non-metallic coatings (ISO 14577-4:2007)
EN ISO 16808:2014 Metallic materials - Sheet and strip - Determination of biaxial stress-strain curve by means of bulge test with optical measuring systems (ISO 16808:2014)
[I]EN ISO 16859-1:2015 Metallic materials - Leeb hardness test - Part 1: Test method (ISO 16859-1:2015) - missing VE
EN ISO 16859-2:2015 Metallic materials - Leeb hardness test - Part 2: Verification and calibration of the testing devices (ISO 16859-2:2015) - mising VE
EN ISO 16859-3:2015 Metallic materials - Leeb hardness test - Part 3: Calibration of reference test blocks (ISO 16859-3:2015) - missing VE[/I]
EN ISO 18265:2013 Metallic materials - Conversion of hardness values (ISO 18265:2013)
EN ISO 20482:2013 Metallic materials - Sheet and strip - Erichsen cupping test (ISO 20482:2013)
EN ISO 26203-1:2010 Metallic materials - Tensile testing at high strain rates - Part 1: Elastic-bar-type systems (ISO 26203-1:2010)
EN ISO 26203-2:2011 Metallic materials - Tensile testing at high strain rates - Part 2: Servo-hydraulic and other test systems (ISO 26203-2:2011)
[url]http://hugefiles.net/2qg8zia81bj8[/url]
or
[url]http://www.mediafire.com/download/rdt82zwep1u76fq/Test_Methods_For_Steel.rar[/url]
updated with few missing standards...now, full list od standards (they issued one new) is:
EN ISO 7500-1:2015 Metallic materials - Calibration and verification of static uniaxial testing machines - Part 1: Tension/compression testing machines - Calibration and verification of the force-measuring system (ISO 7500-1:2015)
missing only 2 valid editions now:
and
new links for this collection:
[url]http://hugefiles.net/wvninhpk5z4v[/url]
or
[url]http://www.mediafire.com/download/nrqux7h8vfc1mgf/Test_Methods_For_Steel_Other_Than_Chemycal_Analysis.rar[/url]
updated with some better versions of standards...missing ones are now:
EN ISO 7438:2016 Metallic materials - Bend test (ISO 7438:2016)
new links:
[url]http://hugefiles.net/vb1y6a7nohur[/url]
or
[url]http://www.mediafire.com/download/y6l3rnphhtd6g8e/TMFS.rar[/url]
new links:
or
Dear sir,
u r done great job....but really very difficult to download all the standards every time....if you update new standards, it should be download seperately...pls consider my point ...do need ful sir.....thanks for sharing
thanking you
just fresh linkz, no update:
[url]http://hugefiles.net/q1a49m2xlb6z[/url]
update:
[url]http://hugefiles.net/rwtanok0bvap[/url]
or
[url]http://www.mediafire.com/download/2prq3x2206y1orv/BS_EN_ISO_7438-2016.pdf[/url]
anyone have this missing standard from this sector:
anyway, fresh links:
[url]http://hugefiles.net/tv0ptbzdymiy[/url]
or
[url]http://www.mediafire.com/download/9ab3zfpczu0aa7b/nochem.rar[/url]
Here u go .........!!!!!!!!
EN ISO 7500-1:2015
now also completed sector....thanx
thanks to amjadmalik75 sector is complete:
[url]http://www.mediafire.com/download/ofh58i9ssd85s74/tmet4steel.rar[/url]
update:
EN ISO 643:2012 Steels - Micrographic determination of the apparent grain size (ISO 643:2012) - EN version
EN ISO 6892-1:2016 Metallic materials - Tensile testing - Part 1: Method of test at room temperature (ISO 6892-1:2016) - added new standard
missing one now is:
EN ISO 6508-1:2016 Metallic materials - Rockwell hardness test - Part 1: Test method (ISO 6508-1:2016)
links:
[url]https://1fichier.com/?7b94mjb5s9[/url]
or
[url]http://www.mediafire.com/download/rj9oty9yb6ttw3h/testmetd.rar[/url]
Dear Borntosin,
Please Post ISO 13665 PLEASE;
WITH REGARDS
AKASH
update:
EN ISO 6508-1:2016 Metallic materials - Rockwell hardness test - Part 1: Test method (ISO 6508-1:2016) - added missing standard
sector complete again
[url]http://www.mediafire.com/file/rj9oty9yb6ttw3h/testmetd.rar[/url]
or
[url]https://1fichier.com/?hl50ce4036[/url]
update:
EN ISO 148-1:2016 Metallic materials - Charpy pendulum impact test - Part 1: Test method (ISO 148-1:2016) - added new edition of standard
EN ISO 148-3:2016 Metallic materials - Charpy pendulum impact test - Part 3: Preparation and characterization of Charpy V-notch test pieces for indirect verification of pendulum impact machines (ISO 148-3:2016) - added new edition of standard
the new missing ones are:
EN ISO 148-2:2016 Metallic materials - Charpy pendulum impact test - Part 2: Verification of testing machines (ISO 148-2:2016)
EN ISO 14577-4:2016 Metallic materials - Instrumented indentation test for hardness and materials parameters - Part 4: Test method for metallic and non-metallic coatings (ISO 14577-4:2016)
new links:
[url]https://1fichier.com/?04a0t9wxfi[/url]
or
[url]http://www.mediafire.com/file/0pyih8d0usihf0d/ISO_148-2-2016.pdf[/url]
or
[url]https://1fichier.com/?nyyc4hno8x[/url]
update:
better quality of:
still missing:
new links:
or
[url]https://1fichier.com/?r0viv1oxcr[/url]
