CEN Standards Collection 2/370: CEN TC 138 - Non-Destructive Testing
More than 90% valid CEN/EN standards....just download, open the excel file, and click :)
[url]http://hugefiles.net/dkwztd1hr1yt[/url]
Re: CEN standars collection 2/100: CEN TC 138 - Non-Destructive Tetsing
104 standards...
95 valid editions, 9 is missing valid editions:
[B]Ionizing radiation[/B]
EN 1330-3:1997 Non-destructive testing - Terminology - Part 3: Terms used in industrial radiographic testing
EN ISO 5579:2013 Non-destructive testing - Radiographic testing of metallic materials using film and X- or gamma rays - Basic rules (ISO 5579:2013)
EN ISO 11699-1:2011 Non-destructive testing - Industrial radiographic film - Part 1: Classification of film systems for industrial radiography (ISO 11699-1:2008)
EN ISO 11699-2:2011 Non-destructive testing - Industrial radiographic films - Part 2: Control of film processing by means of reference values (ISO 11699-2:1998)
EN 12543-1:1999 Non-destructive testing - Characteristics of focal spots in industrial X-ray systems for use in non-destructive testing - Part 1: Scanning method
EN 12543-2:2008 Non-destructive testing - Characteristics of focal spots in industrial X-ray systems for use in non-destructive testing - Part 2: Pinhole camera radiographic method
EN 12543-3:1999 Non-destructive testing - Characteristics of focal spots in industrial X-ray systems for use in non-destructive testing - Part 3: Slit camera radiographic method
EN 12543-4:1999 Non-destructive testing - Characteristics of focal spots in industrial X-ray systems for use in non-destructive testing - Part 4: Edge method
EN 12543-5:1999 Non-destructive testing - Characteristics of focal spots in industrial X-ray systems for use in non-destructive testing - Part 5: Measurement of the effective focal spot size of mini and micro focus X-ray tubes
EN 12544-1:1999 Non-destructive testing - Measurement and evaluation of the X-ray tube voltage - Part 1: Voltage divider method
EN 12544-2:2000 Non-destructive testing - Measurement and evaluation of the X-ray tube voltage - Part 2: Constancy check by the thick filter method
EN 12544-3:1999 Non-destructive testing - Measurement and evaluation of the X-ray tube voltage - Part 3: Spectrometric method
EN 12679:1999 Non-destructive testing - Determination of the size of industrial radiographic sources - Radiographic method
EN 13068-1:1999 Non-destructive testing - Radioscopic testing - Part 1: Quantitative measurement of imaging properties
EN 13068-2:1999 Non-destructive testing - Radioscopic testing - Part 2: Check of long term stability of imaging devices
EN 13068-3:2001 Non-destructive testing - Radioscopic testing - Part 3: General principles of radioscopic testing of metallic materials by X- and gamma rays
EN 14096-1:2003 Non-destructive testing - Qualification of radiographic film digitisation systems - Part 1: Definitions, quantitative measurements of image quality parameters, standard reference film and qualitative control
EN 14096-2:2003 Non-destructive testing - Qualification of radiographic film digitisation systems - Part 2: Minimum requirements
EN 14784-1:2005 Non-destructive testing - Industrial computed radiography with storage phosphor imaging plates - Part 1: Classification of systems
EN 14784-2:2005 Non-destructive testing - Industrial computed radiography with storage phosphor imaging plates - Part 2: General principles for testing of metallic materials using X-rays and gamma rays
EN 16016-1:2011 Non destructive testing - Radiation methods - Computed tomography - Part 1: Terminology
EN 16016-2:2011 Non destructive testing - Radiation methods - Computed tomography - Part 2: Principle, equipment and samples
EN 16016-3:2011 Non destructive testing - Radiation methods - Computed Tomography - Part 3: Operation and interpretation
EN 16016-4:2011 Non destructive testing - Radiation methods - Computed tomography - Part 4: Qualification
EN 16407-1:2014 Non-destructive testing - Radiographic inspection of corrosion and deposits in pipes by X- and gamma rays - Part 1: Tangential radiographic inspection
EN 16407-2:2014 Non-destructive testing - Radiographic inspection of corrosion and deposits in pipes by X- and gamma rays - Part 2: Double wall radiographic inspection
EN ISO 19232-1:2013 Non-destructive testing - Image quality of radiographs - Part 1: Determination of the image quality value using wire-type image quality indicators (ISO 19232-1:2013)
EN ISO 19232-2:2013 Non-destructive testing - Image quality of radiographs - Part 2: Determination of the image quality value using step/hole-type image quality indicators (ISO 19232-2:2013)
EN ISO 19232-3:2013 Non-destructive testing - Image quality of radiographs - Part 3: Image quality classes (ISO 19232-3:2013)
EN ISO 19232-4:2013 Non-destructive testing - Image quality of radiographs - Part 4: Experimental evaluation of image quality values and image quality tables (ISO 19232-4:2013)
EN ISO 19232-5:2013 Non-destructive testing - Image quality of radiographs - Part 5: Determination of the image unsharpness value using duplex wire-type image quality indicators (ISO 19232-5:2013)
[B]Leak testing[/B]
EN 1330-8:1998 Non-destructive testing - Terminology - Part 8: Terms used in leak tightness testing
EN 1518:1998 Non-destructive testing - Leak testing - Characterization of mass spectrometer leak detectors
EN 1593:1999 Non-destructive testing - Leak testing - Bubble emission techniques
EN 1593:1999/A1:2003 Non-destructive testing - Leak testing - Bubble emission techniques
EN 1779:1999 Non-destructive testing - Leak testing - Criteria for method and technique selection
EN 1779:1999/A1:2003 Non-destructive testing - Leak testing - Criteria for method and technique selection
EN 13184:2001 Non-destructive testing - Leak testing - Pressure change method
EN 13184:2001/A1:2003 Non-destructive testing - Leak testing - Pressure change method
EN 13185:2001 Non-destructive testing - Leak testing - Tracer gas method
EN 13185:2001/A1:2003 Non-destructive testing - Leak testing - Tracer gas method
EN 13192:2001 Non destructive testing - Leak testing - Calibration of reference leaks for gases
EN 13625:2001 Non-destructive testing - Leak test - Guide to the selection of instrumentation for the measurement of gas leakage
[B]Eddy current[/B]
EN ISO 12718:2008 Non-destructive testing - Eddy current testing - Vocabulary (ISO 12718:2008)
EN ISO 15548-1:2013 Non-destructive testing - Equipment for eddy current examination - Part 1: Instrument characteristics and verification (ISO 15548-1:2013)
EN ISO 15548-2:2013 Non-destructive testing - Equipment for eddy current examination - Part 2: Probe characteristics and verification (ISO 15548-2:2013)
EN ISO 15548-3:2008 Non-destructive testing - Equipment for eddy current examination - Part 3: System characteristics and verification (ISO 15548-3:2008)
EN ISO 15549:2010 Non-destructive testing - Eddy current testing - General principles (ISO 15549:2008)
[B]Methodology for qualification[/B]
CEN/TR 14748:2004 Non-destructive testing - Methodology for qualification of non-destructive tests
[B]Visual examination[/B]
EN 1330-10:2003 Non-destructive testing - Terminology - Part 10: Terms used in visual testing
EN 13018:2001 Non-destructive testing - Visual testing - General principles
EN 13018:2001/A1:2003 Non-destructive testing - Visual testing - General principles
EN 13927:2003 Non-destructive testing - Visual testing - Equipment
[B]Penetrants[/B]
EN ISO 3059:2012 Non-destructive testing - Penetrant testing and magnetic particle testing - Viewing conditions (ISO 3059:2012)
EN ISO 3452-1:2013 Non-destructive testing - Penetrant testing - Part 1: General principles (ISO 3452-1:2013)
EN ISO 3452-2:2013 Non-destructive testing - Penetrant testing - Part 2: Testing of penetrant materials (ISO 3452-2:2013)
EN ISO 3452-3:2013 Non-destructive testing - Penetrant testing - Part 3: Reference test blocks (ISO 3452-3:2013)
EN ISO 3452-4:1998 Non-destructive testing - Penetrant testing - Part 4: Equipment (ISO 3452-4:1998)
EN ISO 3452-5:2008 Non-destructive testing - Penetrant testing - Part 5: Penetrant testing at temperatures higher than 50 degrees C (ISO 3452-5:2008)
EN ISO 3452-6:2008 Non-destructive testing - Penetrant testing - Part 6: Penetrant testing at temperatures lower than 10 degrees C (ISO 3452-6:2008)
EN ISO 12706:2009 Non-destructive testing - Penetrant testing - Vocabulary (ISO 12706:2009)
CEN/TR 16638:2014 Non-destructive testing - Penetrant and magnetic particle testing using blue light
[B]X-Ray diffraction[/B]
EN 1330-11:2007 Non-destructive testing - Terminology - Terms used in X-ray diffraction from polycrystalline and amorphous materials
EN 13925-1:2003 Non-destructive testing - X-ray diffraction from polycrystalline and amorphous material - Part 1: General principles
EN 13925-2:2003 Non-destructive testing - X-ray diffraction from polycrystalline and amorphous materials - Part 2: Procedures
EN 13925-3:2005 Non destructive testing - X ray diffraction from polycrystalline and amorphous materials - Part 3: Instruments
EN 15305:2008 Non-destructive Testing - Test Method for Residual Stress analysis by X-ray Diffraction
EN 15305:2008/AC:2009 Non-destructive Testing - Test Method for Residual Stress analysis by X-ray Diffraction
[B]Ultrasonic[/B]
EN 1330-4:2010 Non-destructive testing - Terminology - Part 4: Terms used in ultrasonic testing
EN ISO 7963:2010 Non-destructive testing - Ultrasonic testing - Specification for calibration block No. 2 (ISO 7963:2006)
EN ISO 2400:2012 Non-destructive testing - Ultrasonic testing - Specification for calibration block No. 1 (ISO 2400:2012)
EN 12668-1:2010 Non-destructive testing - Characterization and verification of ultrasonic examination equipment - Part 1: Instruments
EN 12668-2:2010 Non-destructive testing - Characterization and verification of ultrasonic examination equipment - Part 2: Probes
EN 12668-3:2013 Non-destructive testing - Characterization and verification of ultrasonic examination equipment - Part 3: Combined equipment
EN 14127:2011 Non-destructive testing - Ultrasonic thickness measurement
CEN/TR 15134:2005 Non-destructive testing - Automated ultrasonic examination - Selection and application of systems
EN 15317:2013 Non-destructive testing - Ultrasonic testing - Characterization and verification of ultrasonic thickness measuring equipment
EN 16018:2011 Non-destructive testing - Terminology - Terms used in ultrasonic testing with phased arrays
EN ISO 16810:2014 Non-destructive testing - Ultrasonic testing - General principles (ISO 16810:2012)
EN ISO 16811:2014 Non-destructive testing - Ultrasonic testing - Sensitivity and range setting (ISO 16811:2012)
EN ISO 16823:2014 Non-destructive testing - Ultrasonic testing - Transmission technique (ISO 16823:2012)
EN ISO 16826:2014 Non-destructive testing - Ultrasonic testing - Examination for discontinuities perpendicular to the surface (ISO 16826:2012)
EN ISO 16827:2014 Non-destructive testing - Ultrasonic testing - Characterization and sizing of discontinuities (ISO 16827:2012)
EN ISO 16828:2014 Non-destructive testing - Ultrasonic testing - Time-of-flight diffraction technique as a method for detection and sizing of discontinuities (ISO 16828:2012)
[I]EN ISO 16932-2: 2014 Non-destructive testing - Characterisation and verification of ultrasonic phased array equipment - Part 2: Probes - missing
EN ISO 16946:2015 Non-destructive testing - Ultrasonic testing - Specification for step wedge calibration block (ISO 16946:2015) - missing VE
EN ISO 17405: 2014 Non-destructive testing - Ultrasonic testing - Technique of testing claddings produced by welding, rolling and explosion (ISO 17405:2014) - missing VE
EN ISO 18563-1:2015 Non-destructive testing - Characterization and verification of ultrasonic phased array equipment - Part 1: Instruments (ISO 18563-1:2015) - missing VE[/I]
[B]Accoustic emission[/B]
EN 1330-9:2009 Non-destructive testing - Terminology - Part 9: Terms used in acoustic emission testing
CEN ISO/TR 13115:2011 Non-destructive testing - Methods for absolute calibration of acoustic emission transducers by the reciprocity technique (ISO/TR 13115:2011)
EN 13477-1:2001 Non-destructive testing - Acoustic emission - Equipment characterisation - Part 1: Equipment description
EN 13477-2:2010 Non-destructive testing - Acoustic emission - Equipment characterisation - Part 2: Verification of operating characteristic
EN 13554:2011 Non-destructive testing - Acoustic emission testing - General principles
EN 14584:2013 Non-destructive testing - Acoustic emission testing - Examination of metallic pressure equipment during proof testing - Planar location of AE sources
EN 15495:2007 Non Destructive testing - Acoustic emission - Examination of metallic pressure equipment during proof testing - Zone location of AE sources
EN 15856:2010 Non-destructive testing - Acoustic emission - General principles of AE testing for the detection of corrosion within metallic surrounding filled with liquid
EN 15857:2010 Non-destructive testing - Acoustic emission - Testing of fibre-reinforced polymers - Specific methodology and general evaluation criteria
[B]Magnetic[/B]
EN 1330-7:2005 Non-destructive testing - Terminology - Part 7: Terms used in magnetic particle testing
[I]EN ISO 9934-1:2015 Non-destructive testing - Magnetic particle testing - Part 1: General principles (ISO 9934-1:2015) - missing VE
EN ISO 9934-2:2015 Non-destructive testing - Magnetic particle testing - Part 2: Detection media (ISO 9934-2:2015) - missing VE
EN ISO 9934-3:2015 Non-destructive testing - Magnetic particle testing - Part 3: Equipment (ISO 9934-3:2015) - missing VE
[/I]
[B]Personnel[/B]
EN ISO 9712:2012 Non-destructive testing - Qualification and certification of NDT personnel (ISO 9712:2012)
[I]CEN/TR 15589:2014 Non destructive testing - Code of practice for the approval of NDT personnel by recognised third party organisations under the provisions of Directive 97/23/EC - missing VE[/I]
CEN/TR 16332:2012 Non-destructive testing - Interpretation of EN ISO/IEC 17024 for NDT personnel certification application
[I]EN ISO 18490:2015 Non-destructive Testing - Evaluation of vision acuity of NDT personnel (ISO 18490:2015) - missing VE[/I]
CEN ISO/TR 25107:2006 Non-destructive testing - Guidelines for NDT training syllabuses (ISO/TR 25107:2006)
CEN ISO/TR 25108:2006 Non-destructive testing - Guidelines for NDT personnel training organizations (ISO/TR 25108:2006)
[B]Various[/B]
EN 1330-1: 2014 Non destructive testing - Terminology - Part 1: List of general terms
EN 1330-2:1998 Non destructive testing - Terminology - Part 2: Terms common to the non-destructive testing methods
CR 13935:2000 Non-destructive testing - Generic NDE data format model
CEN/TS 15053:2005 Non-destructive testing - Recommendations for discontinuities-types in test specimens for examination
CEN ISO/TS 21432:2005 Non-destructive testing - Standards test method for determining residual stresses by neutron diffraction (ISO 21432:2005)
CEN ISO/TS 21432:2005/AC:2009 Non-destructive testing - Standards test method for determining residual stresses by neutron diffraction (ISO 21432:2005/Cor 1:2008)
EN 25580:1992 Non-destructive testing - Industrial radiographic illuminators - Minimum requirements (ISO 5580:1985)
Now on mediafire too:
[url]http://www.mediafire.com/download/0yacra17w7idd4y/Non-Destructive_Testing.rar[/url]
Excellent work...once again!!!
Updated with few missing standards...hugefiles & mediafire links:
[url]http://hugefiles.net/et6j8ermm8c0[/url]
or
[url]http://www.mediafire.com/download/dbuivmcbd71dx28/Non-Destructive_Testing%282%29.rar[/url]
[QUOTE=BornToSin;316359]Updated with few missing standards...hugefiles & mediafire links:
or
[url]http://www.mediafire.com/download/dbuivmcbd71dx28/Non-Destructive_Testing%282%29.rar[/url][/QUOTE]
Dear Santa , Thanks for the files , I check la information for the post # 4 and in the last shared Non-Destructive_Testing(2), I think that you forgot the folder methodology for qualification and inside the file CEN/TR 14748:2004 Non-destructive testing - Methodology for qualification of non-destructive tests , It appears in the post #2.
I will believe you... :D
here is the new link with NDT sector of CEN:
[url]http://www.mediafire.com/download/15b7j44l5jy88pm/Non_Destructive_Testing.rar[/url]
[QUOTE=BornToSin;316434]I will believe you... :D
[url]http://www.mediafire.com/download/15b7j44l5jy88pm/Non_Destructive_Testing.rar[/url][/QUOTE]
Dear BornTosin , thanks for the files , I checking the folders and in the last post #6 in the folder ultrasonic , you forgot the files
BS EN ISO 17405-2014 (793 KB) and ISO 18563-1-2015 (2.05 MB ) . I quickly review and comparing the order and size of files (KB or MB)
the post # 4 has this standars.
I apologize for any inconvenience, warning you for your consideration.
ok...i will concentrate myself and fix it tonight ;)
Thanks for sharing... Some documents are in German language, is there a chance you guys to share the English version?
I also prefer ENG language, but when you can't find it....
anyway, anyone can distribute with missing standards:
updated with few EN versions of standards and one new GER draft version of standard....we still missing here only 4 standards:
EN ISO 18563-3:2015 Non-destructive testing - Characterization and verification of ultrasonic phased array equipment - Part 3: Combined systems (ISO 18563-3:2015)
[url]http://hugefiles.net/6xhir6d7w9k4[/url]
or
[url]http://www.mediafire.com/download/l7zkydoj2l8v2z1/Non_Destructive_Testing%282%29.rar[/url]
thank you so much
matur suwun suanget
now it's updated again tnx to you guys...we only now missing just one standard from here...
anyone have?
new links with updates:
[url]http://hugefiles.net/cbqgoz1qhy0e[/url]
or
[url]http://www.mediafire.com/download/1ff9h4kbl4ganza/NDT.rar[/url]
Re: CEN Standards Collection 2/300: CEN TC 138 - Non-Destructive Tetsing
Many thanks BornToSin for your great effort
can you try to upload the updated standard only to be easier in download
I know it would be much easier, but...CEN sectors are changing all the time, sometimes I need to upload again excel "data sheet" because of new editions...and the problem is hat sometimes I forgot what is actually updated with missing standards + the links sometimes goes down....eh
2 Attachment(s)
A clean copy of ISO TR 25107 - 2006 and ISO TR 25108 - 2006
Enjoy!!
4 Attachment(s)
Here are 100% clean copies of the following.
ISO 16810 - 2012 (without the top and bottom cropped)
ISO 16811 - 2012
ISO 16823 - 2012
ISO 16826 - 2012
Enjoy!
3 Attachment(s)
Also,
ISO 16827 - 2012
ISO 16828 - 2012
ISO 16831 - 2012
Enjoy!!
