Hi all,
I need to know how I can calculate the rate of purge gas in flare header.
Printable View
Hi all,
You should find what you're looking for on exxon DP - shared on this site in the past
read Fluor Daniel Manuals - Flare Design posted by mhuelva: and attached Shell DEP
best regards
inzenjer
thk for DP Shell!!!!
regards!!!!!!
Barbara
You can find a formula for this in API std. 521 (2007), section 7.3.3.3.3
regard
Thanks for the Shell DP doc!!
akosan4six
akosan4six:)
polaris44 has posted Shell DEP v25 and v28
search site for his posts
best regards
Thanks for the Shell DP doc.
We have had and experience with venting a pig launcher to atmosphere. I'm talking about Natural Gas at 500psi. The venting supposed to be controlled but the operator rushed it and the gas ignited.
In our vent pipes we install flap caps to avoid rain water get in. After an investigation of the installation it was found the the metal cap was not connected to earth and electrostatic charge was the cause.
[QUOTE=inzenjer;65334]read Fluor Daniel Manuals - Flare Design posted by mhuelva: and attached Shell DEP
best regards
inzenjer[/QUOTE]
[URL="http://www.4shared.com/file/94577855/c6ce9925/flare_design_manual_vol_48_rev1_.html"]http://www.4shared.com/file/94577855/c6ce9925/flare_design_manual_vol_48_rev1_.html[/URL]
regards
inzenjer and mhuelva: thanks for sharing
Thank you
thanks!!!!
:D
[QUOTE=mhuelva;66238][URL="http://www.4shared.com/file/94577855/c6ce9925/flare_design_manual_vol_48_rev1_.html"]http://www.4shared.com/file/94577855/c6ce9925/flare_design_manual_vol_48_rev1_.html[/URL]
regards[/QUOTE]
the file is missing in the link..plz reupload....
[QUOTE=pulsar3220;70968]the file is missing in the link..plz reupload....[/QUOTE]
[URL="http://ifile.it/lj61ibs"]http://ifile.it/lj61ibs[/URL]
thanks!!!!!!!!!!! :)
I also need the Flare design manual...but your link is not valid...
Could you please send me a valid link or the pdf file?
Thanks.
[QUOTE=eftcat;71701]I also need the Flare design manual...but your link is not valid...
Thanks.[/QUOTE]
Thank you friends.....i was in search of it........
CHEERS.....
hi every body,
Im a newbie of this forum. Im taking the internship in the fertilizer plant, so i would like to ask about experience of working in this kind of plant
or some operating documents related.
thanks in advance
with the best wishes .
