Re: PSCAD 4.2.0 Professional
Hello Manuel
Thanks for your aportation, I need to help, I do not know to install the PSCAD, please help me
Hello Manuel
Hello my friend. The installation its very easy on windows XP, on windows 7 there are some considerations.
For XP just run the setup.exe file, install PSCAD and don't open it yet. It is important that you have a GNU Fortran installation pack that can be found here:
[URL]http://www.4shared.com/zip/iZ7Tac4Fba/ecgs.html[/URL]
Just follow the instructions. Some times an error is shown, first install the GNU Fortran and then install PSCAD. When it ask you for the installation of Fortran just cancel that step.
Then open the "c r a c k" folder and put the m e d i c i n e in the same directory with pscad.exe and execute it. PSCAD.exe can be found in C:\...\PSCAD420Eval\bin\win.
For windows 7 the setup.exe of PSCAD only runs in compatibility mode. Just left click on setup.exe, Properties, Compatibility, Check "Execute this program in compatibility mode for" Windows XP.
Hope it helps.
Thanks my friend, the PSCAD is installed succefully, you are great.
Bes Regards.
A additional question, do you have Digsilent 15, cyme 7 full version or etap 12?
Bes Regards.
A additional question, do you have Digsilent 15, cyme 7 rev 5 or etap 12?
Another question do you have a m-e-d-i-c-i-n-e of CEGS SES, please!!!!!!!!!!!!!!!!!!!
Some of those software are in the forum. Not the version you are asking but a very new one, for digsilent there is the 14.1 i think. Search in the forum and the posts my friend.
thankyou manuel
you are great !
best reagards
PSCAD 4.2.0 doesn't recognize the GNU Fortran Compiler, is there a way to manually set the compiler path?
Hi, the m e d i c i n e (3kb) does not work! i have win7 system, also tried with compatibility mode, but no work? any advise? thx!
Problem with the M E D I C I N E is
Number of buses is limited to 14 more that that it is not accepting - any one can try the examples program
I have use the program and it works fine for windows XP and 7 32 bits. Double checked.
[QUOTE=manuel_cv;250385]Hello colleagues.
Sharing a working PSCAD 4.2.0 Professional Ed. Link still working on the web.
[URL]http://www.4shared.com/file/LcnkObUz/PSCAD_42_pro.html[/URL]
And my personal collaboration, another link with useful information and tutorials about PSCAD.
[URL]http://www.4shared.com/rar/K8iIbeface/Tutorials.html[/URL]
Hope this information be useful for all.[/QUOTE]
Thank you very much
[QUOTE=aetap;271715]Problem with the M E D I C I N E is
Number of buses is limited to 14 more that that it is not accepting - any one can try the examples program[/QUOTE]
Please try again. I have installed this I think last year and it works fine.
Hi,
I have PSCAD 4.2 with ***** but when I execute the ***** to be able to activate the professional version, nothing happens. the PSCAD is still in student version. I am using Windows 10 laptop computer. Hope someone could help me. Thanks.
