Dear All
I am looking for HEI Standards for Steam Surface Condensers 10th or 11th edition.
can you Please share.
Printable View
Dear All
Is anyone able to provide the 11th Edition (2012) for HEI Standard 2629 for Steam Surface Condensers?
Your help would be greatly appreciated.
see link:
[url]http://www.mediafire.com/view/a7ti0h1bny2hcgp/HEI_2629-2012_%28E11%29_Standards_for_Steam_Surface_Condensers.pdf[/url]
Thank you engineer79. Your kindness is appreciated.
I am also having to work with some other outdated HEI standards. I am wondering if you have links for the latest available versions of these HEI standards:
HEI 2633 Standards for Steam Jet Vacuum Systems, 7th Edition, 2012
HEI 2854 Performance Standards for Liquid Ring Vacuum Pumps, 4th Edition, 2010
The addendum 1 for the steam surface condensers appears to be here...
[url]https://www.scribd.com/doc/94283645/Hei-Standards-for-Steam-Surface-Condensers-Add-1[/url]
someone with access please repost
the addendum is for the old ninth edition; the eleventh edition does not require this addendum.
[QUOTE=Marty Thompson;318313]The addendum 1 for the steam surface condensers appears to be here...
someone with access please repost[/QUOTE]
*** deleted ***
only have 2854, see link below:
[url]http://www.mediafire.com/view/0t3gvnmtui0jzmt/HEI_2854-2011_%28E4%29_Performance_Standard_for_Liquid_Ring_Vacuum_Pumps.pdf[/url]
2633 does not exist; based on latest catalogue, steam jet vacuum systems is 2866; however, i do not have it or any older editions.
[QUOTE=marwanab;318312]Thank you engineer79. Your kindness is appreciated.
HEI 2854 Performance Standards for Liquid Ring Vacuum Pumps, 4th Edition, 2010[/QUOTE]
OK, that is the 9th. When you download the 11th contents from the HEI site, it appears to have an addendum 1 dated 2014
look at this downloaded from there... the last page
oh... i'm not aware of the 2014 addendum for the eleventh edition.
thank you for pointing out, marty.
unfortunately, the set of data i have only is only dated up til 2012.
so, i do not have the addendum 1 for the eleventh edition.
maybe others can help?
[QUOTE=Marty Thompson;318321]OK, that is the 9th. When you download the 11th contents from the HEI site, it appears to have an addendum 1 dated 2014
look at this downloaded from there... the last page[/QUOTE]
It appears that the
Standards and Typical Specifications for Tray-Type Deaerators - 9th Ed. 2011 Contents also has a 2014 addendum 1
HEI Tech Sheets
Tube Tech Sheets
• Tech Sheet #129: Common NDE Tube Test Methods
• Tech Sheet #126: Accepted Practices for Packaging
• Tech Sheet #132: Comparison of OD and ID Eddy-Current Inspection of Tubing
• Tech Sheet #134: Heat Treatment of Tubes for Condenser, Feedwater Heater, and Shell & Tube Heat Exchangers
• Tech Sheet #135: A Comparison of Welded & Seamless Heat Exchanger Tubing
Shell & Tube Heat Exchanger Tech Sheets
• Tech Sheet #133: Basics of Shell & Tube Heat Exchangers
• Tech Sheet #137: Heat Exchanger Cladding
Feedwater Heater Tech Sheets
• Tech Sheet #128: Typical Feedwater Heater Cold Start-Up
• Tech Sheet #127: Basics of Closed Feedwater Heaters
• Tech Sheet #106: Specification of Tube Hole Sizes and Tolerances for Support and Baffle Plates
Vacuum Technology Tech Sheets
• Tech Sheet #130: Vacuum Condenser Drainage - Proper Design & Installation Guide
• Tech Sheet #110: Vacuum Systems: Understanding a Key Component of a Modern Power Plant
• Tech Sheet #107: Frequently Asked or Interesting Vacuum System Questions
• Tech Sheet #104: Ejector Throttling
• Tech Sheet #103: Ejector Discharge Pressure
Condenser Tech Sheets
• Tech Sheet #136: Condenser Hotwells
• Tech Sheet #131: Vacuum Breaker Valve
• Tech Sheet #125: Condenser Tube Cleaning
• Tech Sheet #124: Relief Valves vs. Rupture Discs
• Tech Sheet #123: Steam Inlet Expansion Joints
• Tech Sheet #122: Condenser Modular Replacement vs.Retube
• Tech Sheet #117: Waterbox Coating
• Tech Sheet #113: Condenser Basics
• Tech Sheet #101: Operational Alert on Steam Dumps
• HEI Typical Specification for Steam Surface Condensers Appendix A
• HEI Surface Condenser Data Sheet Appendix H
Deaerator Tech Sheets
• Tech Sheet #121: Vacuum Relief
• Tech Sheet #120: Steam Pressure Control Valves
• Tech Sheet #119: Safety and Relief Valves
• Tech Sheet #118: Level Control
• Tech Sheet #114: Deaerator Accessories
• Tech Sheet #112: Technical Discussion on Pressure Vessel Post Weld Heat Treatment
• Tech Sheet #111: Radiographic Testing (RT) Deaerator Vessels
• Tech Sheet #108: Magnetic Particle Testing in New Deaerators
• Tech Sheet #105: Deaerator Troubleshooting Guide
Missing #109, it was not downloadable
[url]http://www.4shared.com/zip/V8otr5G6ce/HEI_Tech_Sheets.html[/url]
Here is a link to HEI Standard for Steam Jet Vacuum Systems, 5th Edition, 2000
[url]https://www.scribd.com/doc/41637114/HEI-Standards-for-Steam-Jet-Vacuum-Systems-5th[/url]
If anyone has the latest edition, [B][U]7th Edition HEI Standard for Steam Jet Vacuum Systems, 7th Edition, 2012 [/U][/B]please share.
Thanks engineer79 and Marty for sharing the HEI documents you have.
If anyone has the [B]HEI Standard for Tray Type Deaerators 9th Ed 2011[/B], I have not seen this posted yet also.
[QUOTE=marwanab;318327]Here is a link to HEI Standard for Steam Jet Vacuum Systems, 5th Edition, 2000
If anyone has the [B]HEI Standard for Tray Type Deaerators 9th Ed 2011[/B], I have not seen this posted yet also.[/QUOTE]
see link below:
[url]http://www.mediafire.com/view/1i1cx1clxsdbfs8/HEI_2954-2011_%28E9%29_Standards_and_Typical_Specifications_for_Tray_Type_Deaerators.pdf[/url]
Engineer79, [U]Thank you[/U] for these up-to-date HEI standards. Would you also have the following available for sharing?
[B]HEI Standards for Closed Feedwater Heaters 8th Edition (2009)
HEI Standards for Direct Contact Barometric and Low Level Condensers, 8th Ed (2010)
Standards for Steam Jet Vacuum Systems 6th or 7th Ed
[/B]
[/B]
Also, attached is the missing [B]HEI Tech Sheet 109 Corrosion Allowance in Deaerator Design[/B]
Thanks everyone for sharing to make this a good community. :joyous:
Here is an HEI order sheet from May 2015 that shows the recent editions and addendums that we all could use.
see link below:
[url]http://www.mediafire.com/view/nxczs01cwomnqgy/HEI_2622-2009_%28E8%29_Standards_for_Closed_Feedwater_Heaters.pdf[/url]
see link below:
