For whom wants to learn petrophysics:
[URL="http://www.megaupload.com/?d=0IOO6CJ8"]Megaupload[/URL]
To make it works without problems, remember to use a short path name to extract the files (for example:"d:\petro\").
Enjoy :)
Printable View
Enjoy :)
can u tell me the content of this module,
Here's the [URL="http://ifile.it/hy0r71f"]content[/URL].
Great,Thanks alot
i downloaded all parts, but when i open it, nothing happen
does it work on XP normally and which microsoft Office are u using?
[QUOTE=A.Zoro;26506]i downloaded all parts, but when i open it, nothing happen
Thanks[/QUOTE]
I use XP service pack 3. Check if flash player is installed, if yes don't use long names for the folder or the path (don't run it from "My Documents" or the Desktop), or try to burn it on CD.
Good luck!
i tested it on vista and xp, both not working
can u tell me which Microsoft Office version ur working at ?
I use Microsoft office 2003 on my desktop and office 2007 on my laptop and it works on both. Do you have macromedia flash player installed?
which version do u have? i have 10
Thank you. I ran the application. Working fine.
I tested it with v9 and 10 and it works perfectly. Does it display any error message?
Does anyone have the same problem?
no error message, it beep for an error but it don't display
i tried at my PC in collage and it didn't work too, same problem
I don't know the difference between flash and shockwave players, but could you try to install shockwave player. I believe that the module has been created with director 7, meanwhile, I'll check the uploaded files.
the problem is related to importing the PICS Rules located in Xtras folder, it doesn't want to be imported
thank great work ... petrophysics are basic
Hi
to run the training change Screen Resolution to 800 X 600 and Color Quality to 16 bit then you can run it.
[email]Ali_Arzani@yahoo.com[/email]
still not working too :(
