ASPEN PLUS 12.1 Instructional Tutorials
[B][FONT=Arial]ASPEN PLUS 12.1 Instructional Tutorials[/FONT][/B]
[FONT=Arial]Developed in the Fall Quarter of 2004 in Chem E 435 (Mass Transfer and Separation): Matthew Bernards and René Overney[/FONT]
[FONT=Arial] [/FONT]
[B]Table of Contents:[/B]
[URL="http://courses.washington.edu/overney/ASPEN_Cover_Index.htm#_Preface"]Preface[/URL]
[URL="http://courses.washington.edu/overney/Aspen/Aspen_Tutorial_Unit_1.pdf"]Tutorial #1[/URL]: Aspen Basics 2
[URL="http://courses.washington.edu/overney/Aspen/Aspen_Tutorial_Unit_2.pdf"]Tutorial #2[/URL]: Convergence and Presentation of Results 11
with Homework and Solution 19
[URL="http://courses.washington.edu/overney/Aspen/Aspen_Tutorial_Unit_3.pdf"]Tutorial #3[/URL]: Flash Separation 21
with Homework and Solution 30
[URL="http://courses.washington.edu/overney/Aspen/Aspen_Tutorial_Unit_4.pdf"]Tutorial #4[/URL]: Thermodynamic Methods 32
with Homework and Solution 37
[URL="http://courses.washington.edu/overney/Aspen/Aspen_Tutorial_Unit_5.pdf"]Tutorial #5[/URL]: Sensitivity Analysis and Transport Properties 39
with Homework and Solution 51
[URL="http://courses.washington.edu/overney/Aspen/Aspen_Tutorial_Unit_6.pdf"]Tutorial #6[/URL]: Distillation 52
with Homework and Solution 65
[URL="http://courses.washington.edu/overney/Aspen/Aspen_Tutorial_Final_Problem.pdf"]Final Homework and Solution[/URL] 69
[URL="http://courses.washington.edu/overney/ASPEN_Cover_Index.htm#_Download_entire_Tutorial:"]Download entire Tutorial[/URL]
[B] [/B]
[B]Preface[/B]
This Tutorial was developed with the Windows Version of [I]ASPEN[/I][I] PLUS 12.1[/I]. Our Site License allows us to install a software version on the personal computer of the instructor and TA. The Tutorial was developed with the idea in mind that it is used and extended in other courses of the ChemE Curriculum. As it currently stands, the tutorial is applicable for students in:
ChemE 310 (Unit Operations): Tutorial Units 1-3,
ChemE 326 (Thermodynamics): Tutorial Units 4 and 5,
ChemE 435 (Mass Transfer and Separations): Tutorial Units 3-6.
Additional unit developments are suggested for:
[FONT=Symbol]·[/FONT][FONT="] [/FONT][FONT="]Chemical Reactions (ChemE 465)[/FONT]
[FONT=Symbol]·[/FONT][FONT="] [/FONT][FONT="]Chemical Reactor Design (ChemE 465)[/FONT]
[FONT=Symbol]·[/FONT][FONT="] [/FONT][FONT="]Heat Streams (ChemE 340 / ChemE 435)[/FONT]
[FONT=Symbol]·[/FONT][FONT="] [/FONT][FONT="]Heat Exchanger Design (ChemE 340)[/FONT]
[FONT=Symbol]·[/FONT][FONT="] [/FONT][FONT="]Pressure Drop Calculations (pipe, pumps, valves, etc.)[/FONT][FONT="] (ChemE 330)[/FONT]
[FONT=Symbol]·[/FONT][FONT="] [/FONT][FONT="]Using Fortran Statements (ChemE 465)[/FONT]
The ASPEN 10.1 Tutorial developed in ChemE 310 by Martin and Babb would provide some background information on Fortran Statements, Chemical Reactions and Heat Streams and Heat Exchanger Design.
[B]Download entire Tutorial:[/B]
[URL="http://courses.washington.edu/overney/Aspen/Aspen_Tutorial.pdf"]PDF version[/URL]
[URL="http://courses.washington.edu/overney/Aspen/Aspen_Tutorial.doc"]MS-Word Version[/URL] for further unit developments and improvements.
