Download Electrical Engineering Program (Excel Base)
Hi ,
I am sharing some useful Excel base Program of Electrical Engineering.
[COLOR="Blue"][B]Cable Designing Program
[/B][/COLOR]
* Calculate Voltage drop of Cable.
* Calculate Size of Cable.
* Calculate Current Capacity of Cable.
[COLOR="Blue"][B]
Conduit Size Selection Program[/B][/COLOR]
* Calculate Size of Conduit for LT Cable/CAT-5 Cable/Fiber Optical Cable.
[COLOR="Blue"][B]
Selection of MCCB,ELCB For Main /Branch Circuit.[/B][/COLOR]
* Calculate Size and Type of Main MCCB/RCCB/ELCB for Continious and Non Continious Load
* Calculate Sensitivity of MCCB/RCCB/ELCB.
* Calculate Size and Type of Sub Circuit MCCB/MCB for Continious and Non Continious Load
* Calculate Total Load .
* Calculate Main and Branch Circuit Current.
[B][COLOR="Blue"]Selection of Fuses[/COLOR][/B]
* Calculate Size of Fuse for Electrical Circuit.
[B][COLOR="Blue"]
Size of Capacitor For Power Factor Improvements[/COLOR][/B]
* Calculate Size of Capacitor for Power Factor Improvements.
* Calculate Annual Saving by selection of Capacitor.
* Calculate Active and Reactive Power.
[B][COLOR="Blue"]Short Circuit Current Calculation at Various Point of Electrical Curcuits(Isc).[/COLOR][/B]
* Calculate Short Circuit Current at Substation.
* Calculate Short Circuit Current at Distribution point.
* Calculate Short Circuit Current at Transformer.
* Calculate Short Circuit Current at Main Panel.
* Calculate Short Circuit Current at Sub Distribution Board.
[B][COLOR="Blue"]Circuit Breaker Tripping Settings.[/COLOR][/B]
* Calculate Tripping Setting of Circuit Breaker.
[B][COLOR="Blue"]Motor Specifications[/COLOR][/B]
* Calculate Various Specification of Motor.
[B][COLOR="Blue"]Calculate Home Electrical Load & Electrical Bill.[/COLOR][/B]
* Calculate Electrical Bill of Home
* Calculate Size of MCCB/MCB for Domestic Load
* Calculate Electrical Load of Home.
[B][COLOR="Blue"]Calculate Insulation Resistance Value and PI value[/COLOR][/B]
* Calculate minimum Insulation Resistance Value for Various Electrical Equipments.
* Calculate IR Value of Electrical Equipments.
* Graph of IR Value
* Calculate Polarization Index Value with Graph
* Calculate Earth Resistivity.
[COLOR="Blue"][B]Calculate Electrical Load and Energy Consumption of Panel.[/B][/COLOR]
* Calculate Continuous and non Continuous Electrical Load of Panel.
* Calculate total Energy Consumption(KWH) in Daily/Monthly of Panel.
* Calculate Size of MCB of each branch circuit of Panel.
* Calculate Voltage / Voltage Difference of Each Phase
* Calculate Unbalanced Load in Neutral Wire.
* Calculate Expected Temperature rise in Each Phase.
* Calculate Load in Each Phase.
* Calculate Starting/Full Load/Continuous/Non Continuous Load
* Calculate Size/Type/Tripping setting of Main MCCB.
[B][COLOR="Blue"]
Calculate Size of Battery Bank and Inverter.[/COLOR][/B]
* Calculate Total Demand Load
* Calculate Size of Battery Bank in Amp.Hr.
* Select Type of Connection of Batteries in Battery Bank
* Select Rating of Each Battery in Battery Bank
* Calculate Size of Inverter
[COLOR="Blue"][B]
Calculate Size of Solar Panel / Battery Bank / Inverter.[/B][/COLOR]
* Calculate Size of Solar Panel.
* Select Type of Connection of Solar Panel.
* Select Rating of Each Solar Panel.
* Calculate Energy from Solar Panel as per Daily Sun lights.
* Calculate Size Battery Bank.
* Select Type of connection of Batteries in Battery Bank
* Calculate size of Inverter
[B][COLOR="Blue"]Calculate No of Lighting Fittings and Lumen Output.[/COLOR][/B]
* Calculate Total Lumen Output for particular Area.
* Calculate Total No of Lighting Lamps.
* Calculate Total No of Lighting Fixtures.
* Calculate No of Fittings along with the Length and Width of Room.
[B][COLOR="Blue"]Calculate Bus Bar Size and Voltage Drop.[/COLOR][/B]
* Calculate Voltage Drop for Bus Bar.
* Select Size of Bus Bar for particular Load.
* Enter Your Sub Panel Details like Load,Line Length.
[B][COLOR="Blue"]
Design of Earthing Mat for Sub-Station:[/COLOR][/B]
* Program is design as per ANSI/IEEE 80-1986 Code.
* Calculate Step Potential of Switch yard.
* Calculate Touch Potential of Switch yard.
* Calculate Total Length of Earthing Mat Conductor.
* Calculate Size of Earthing Mat Conductor.
* Calculate Total No of Earthing Rods.
[B][COLOR="Blue"]Calculate Touch Voltage and Ground Current.[/COLOR][/B]
* Calculate Resistance of Each Phase.
* Calculate Resistance of neutral/Ground.
* Calculate Neutral Current and Load.
* Calculate Touch Voltage for Metal part to Earth.
* Calculate Body Resistance and Body Current.
Download Links: [url]www.jiguparmar.com[/url]
OR
[url]www.jiguparmar.wordpress.com[/url]
hi Jiguparmar,
i tried downloading your excel software but to not avaiable. Can you send to me
[COLOR="#0000CD"]manikandan.ic@gmail.com[/COLOR]
N Manikandan
Re: Download Electrical Engineering Program (Excel Base)
hi Jiguparmar,
i tried downloading your excel software but to not available. Can you send to me
[email]sanjeewaro@yahoo.com[/email]
sanjeewa
Calculate Touch Voltage and Ground Current is not available
thanks for your subject
i hope it will help me
