We usually find ASTM cross reference material Specification table on net......But i want to know this table is extract from which official standard document..............??
Printable View
Faisal,
Are you referring to a table that gives recommendations for compatable pipe, fitting, flanges etc or are you interested in comparing ASTM, EN, ISO, JIS type materials in similar forms? I have seen books regarding the latter. For the former I have only seen tables prepared by engineers who consider compatable metallurgy, code welding categories, allowable stress, minimum design temperatures, Charpy tests requirements and so on...
Well i am referring to recommendations for compatable pipe, fitting, flanges.....just wana know which standard (name of standard) which provide this table....... I know it is easily available on net ....but want to know on which standard this table is found.....?
Faisal,
ASTM F1155 has some infornation but it may not cover the specific process you are interested in.
u mean to say ASTM cross reference material Specification is in ASTM F1155.............. if no then what is the authenticity of this table.............................Do you have this ASTM F1155........?
Faisal,
ASTM F1155 provides guidance for designers of ship board marine type utility systems. I will see if I can find a copy to scan and send to you. If you are looking for oil & gas process system guidance you would be better off looking at the the NORSOK standards L-001 and M-630. If I understand what you are looking for I don't think there is code based "official / authentic" guidance available. Table 1 in M-630 is probably as good a reference as you are going to find. Engineers preparing piping specifications use their judgement and experience when making the choices that go into preparing a piping specification, i.e. welded vs seamless pipe, fluorocarbon coated vs galvanized bolting, RTJ vs NAF cardboard gaskets and so on.
F 1155 - 98 Standard Practice for Selection and Application of Piping System Materials.pdf
[url]http://www.4shared.com/document/_qJIcOT7/F_1155_-_98_Standard_Practice_.html[/url]
Thnx for sharing ........... if one piping material has been finalized for one design conditions for above ground process piping.... how we will select fittings materials for same design conditions ........................ which standard no. deal with that ..........and whats the authentic procedure for fitting material selection..........?
Dear Nabilia,
Please upload the link again.
Thanks & Regards,
Amit
Here it is.....
[url]http://www.mediafire.com/file/1pcm41t7fh8178j/F_1155_-_98.pdf[/url]
[QUOTE=amitrajmane;206497]Dear Nabilia,
Thanks & Regards,
Amit[/QUOTE]
Thanks inconel,
Amit
Thanks inconel,
Amit
Dear Inconel,
Thanks for the useful posting.
rsmyegpet
hello, I need
ASTM D1210 Edition 2010
ASTM D281 Edition 2012
ASTM D2369 Edition 2011
ASTM D3359 Edition 2010
ASTM D1640 Edition 2009
who can help me?
so many thanks
