Fresh from the oven
Specification for the Qualification of Radiographic Interpreters
AWS B5.15:2010 An American National Standard
[url]http://ifile.it/lvzk4tg[/url]
[url]http://ifile.it/lvzk4tg/AWS%20B5.15-2010.pdf[/url]
Printable View
Fresh from the oven
thank you dear
keep posting
D -SERIES
1 AWS D1.0 Welding in Building Construction 1996
2 AWS D1.1 - 2008 Errata only
3 AWS D1.1 - 2008 Structural Welding Code – Steel (ANSI STANDARD)
4 AWS D1.1 Interpretation 1998
5 AWS D1.2-2003 Structural Welding Code—Aluminum (ANSI STANDARD)
6 AWS D1.3/D1.3M-2008 Structural Welding Code - Sheet Steel (ANSI STANDARD)
7 AWS D1.4 Welding Reinforcing Steel 2005 (ANSI STANDARD)
8 AWS D1.5/D1.5M-2002 Bridge Welding Code (ANSI STANDARD)
9 AWS D1.6/D1.6M-2007 Structural Welding Code - Stainless Steel (ANSI STANDARD)
10 AWS D2.0 Specification for welded Highway and Railway Bridges 1996 (ANSI STANDARD)
11 AWS D3.6 Underwater Welding, Specification 1999 (ANSI STANDARD)
12 AWS D8 -2007 Specification for Automotive Weld Quality—Arc Welding of Steel (ANSI STANDARD)
13 AWS D9.1 - 2006 Sheet metal welding code (ANSI STANDARD)
14 AWS D10.4 Welding Austenitic (CrNi )SS ,Piping-Tubing 1986 (ANSI STANDARD)
15 AWS D10.9 - WPS Piping & Tubing 1980
16 AWS D10.10 Local Heating, Welds, Piping-Tubing 1999 (ANSI STANDARD)
17 AWS D10.11 Root Pass Welding of Pipe without Backing 1997 (ANSI STANDARD)
18 AWS D10.12 Guide for Welding Mild Steel Pipe 2000 (ANSI STANDARD)
19 AWS D11.2 Welding Iron Castings 1989 (ANSI STANDARD)
20 AWS D14.1-1997 Specification For Welding Of Industrial And Mill Crane (ANSI STANDARD)
21 AWS D14.4 Welded Joints in Machinery and Equipment 1997 (ANSI STANDARD)
22 AWS D14.5 - Spec. f Welding Presses Components 1997 (ANSI STANDARD)
23 AWS D14.6 Welding of Rotating Elements of Equipment 1996(ANSI STANDARD)
24 AWS D16.4-2005 Specification for the Qualification of Robotic Arc Welding Personnel (ANSI STANDARD)
25 AWS D17.1-2001 Specification for Fusion Welding for Aerospace Applications (ANSI STANDARD)
26 AWS Code Clinic – For Study of AWS D1.I Structural Welding Code – Steel (instruction Manual)
27 AWS Code Clinic – API 1104 Welding of Pipelines and Related facilities
C - SERIES
1 AWS C1 .1 M/C1.1:2000 Recommended Practices for Resistance Welding (ANSI STANDARD)
2 AWS Cl.4M/C1.4:1999 Specification for Resistance Welding of Carbon and Low-Alloy Steels (ANSI STANDARD)
3 AWS C2.18-1993 Guide for the Protection of Steel with Thermal Sprayed Coatings of Aluminum and Zinc and Their Alloys and Composites (ANSI STANDARD)
4 AWS C2.20/C2.20M:2002 Specification for Thermal Spraying Zinc Anodes on Steel Reinforced Concrete (ANSI STANDARD)
5 AWS C2.21M/C2.21:2003 Specification for Thermal Spray Equipment Acceptance Inspection (ANSI STANDARD)
6 AWS C2.23M/C2.23:2003 Specification for the Application of Thermal Spray Coatings (Metalizing) of Aluminum, Zinc, and Their Alloys and Composites for the Corrosion Protection of Steel (ANSI STANDARD) equal to NACE No. 12, SSPC-CS 23.00
7 AWS C3.2M/C3.2:2001 Standard Method for Evaluating the Strength of Brazed Joints (ANSI STANDARD)
8 AWS C3.3:2002 Recommended Practices for the Design, Manufacture, and Examination of
Critical Brazed Components (ANSI STANDARD)
9 AWS C7.1M/C7.1:2004 Recommended Practices for Electron Beam Welding (ANSI STANDARD)
10 AWS C3.4:1999 Specification for Torch Brazing (ANSI STANDARD)
10a AWS C3.6M-C3.6-2008 Specification for Furnace Brazing
11 AWS C3.7:1999 Specification for Aluminum Brazing (ANSI STANDARD)
12 AWS C3.8-1990 Recommended Practices for Ultrasonic Inspection of Brazed Joints (ANSI STANDARD)
13 AWS C4.1-1977 Criteria for Describing Oxygen-Cut Surfaces
14 AWS C4.2:2002 Operator’s Manual for Oxyfuel Gas Cutting (ANSI STANDARD)
15 AWS C4.3-1983 Operators Manual for Oxyfuel Gas Heating Torch Operation (ANSI STANDARD)
16 AWS C5.1-1973 Recommended Practices for Plasma-Arc Welding
17 AWS C5.5/C5.5M:2003 Recommended Practices for Gas Tungsten Arc Welding (ANSI STANDARD)
18 AWS C5.10/C5.10M:2003 Recommended Practices for Shielding Gases for Welding and Cutting (ANSI STANDARD)
AWS – REFERENCE BOOK
1 AWS - Arc Welding Safety, Fumes-Gases 1979
2 AWS - Arc Welding and Cutting Noise 1979
3 AWS - Characterization of Arc Welding Fume 1983
4 AWS - Design for Welding 2003
5 AWS - Design handbook for calculating fillet weld sizes 1997
6 AWS - Economics of Welding and Cutting 2003
7 AWS - Evaluating Welded Joints, Test 2003
8 AWS - Radiographic Inspection Acceptance 1995
9 AWS - Residual Stress and Distortion 2003
10 AWS - Underwater Welding, Offshore Platforms-Pipelines 1980
11 AWS - Vessel & Piping inspection 1999
12 AWS - Welding, Design and Planning Manual 1999
13 AWS - Welding-Joining Processes, Monitor-Control 2003
B SERIES
1 AWS B1.10:1999 Guide for the Nondestructive Examination of Welds (ANSI STANDARD)
2 AWS B1.11:2000 Guide for the Visual Examination of Welds (ANSI STANDARD)
3 AWS B2.1-8-212:2001 Standard Welding Specification (WPS) for Gas Tungsten Arc Welding Stainless Steel (M-8/P-8/S-8, Group 1) , 1/16 through 1-1/2 inch thick, ER3XX, As Welded Conditions, Primarily Pipe Application – Site License (ANSI STANDARD)
4 AWS 82.1 :2000 Specification for Welding Procedure and Performance Qualification (ANSI STANDARD)
5 AWS B2.1-1-208-1996 Standard Welding Specification (WPS) for Shielded Metal Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2) 1/8 through 1-1/2 inch thick, E7018, As Welded or PWHT Condition, Primarily Pipe Application (ANSI STANDARD)
6 AWS B2.1-1-002-2006 Standard Welding Specification (WPS) for Shielded Metal Arc Welding of Carbon Steel (M-1/P-1, Group 1 or 2), 3/16 through 7/8 inch, in the As-Welded Condition, With or Without Backing – Site License (ANSI STANDARD)
7 AWS B2.1-1-201-2007 Standard Welding Specification (WPS) for Shielded Metal Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2), 1/8 through 3/4 inch Thick, E6010 (Vertical Uphill) Followed by E7018 (Vertical Uphill), As-Welded Condition, Primarily Pipe Applications (ANSI STANDARD)
8 AWS B2.1-1-202-2007 Standard Welding Specification (WPS) for Shielded Metal Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2), 1/8 through 3/4 inch Thick, E6010 (Vertical Downhill) Followed by E7018 (Vertical Uphill), As-Welded Condition, Primarily Pipe Applications – Site License (ANSI STANDARD)
9 AWS B2.1-1-203-2007 Standard Welding Specification (WPS) for Shielded Metal Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2), 1/8 through 3/4 inch Thick, E6010 (Vertical Uphill) As-Welded Condition, Primarily Pipe Applications – Site License (ANSI STANDARD)
10 AWS B2.1-1-204-2007 Standard Welding Procedure Specification (SWPS) for Shielded Metal Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2), 1/8 through 3/4 inch Thick, E6010 (Vertical Downhill Root with the Balance Vertical Uphill), As-Welded Condition, Primarily Pipe Applications – Site License (ANSI STANDARD)
11 AWS B2.1-1-205-2007 Standard Welding Procedure Specification (SWPS) forShielded Metal Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2), 1/8 through 1-1/2 inch Thick, E6010 (Vertical Uphill) Followed by E7018 (Vertical Uphill), As-Welded or PWHT Condition, Primarily Pipe Applications – Site License (ANSI STANDARD)
12 AWS B2.1-1-206-96 (R2007) Standard Welding Procedure Specification (SWPS) for Shielded Metal Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2), 1/8 through 1-1/2 inch Thick, E6010 (Vertical Downhill) Followed by E7018 (Vertical Uphill), As-Welded or PWHT Condition, Primarily Pipe Applications – Site License (ANSI STANDARD)
13 AWS B2.1-1-207-96 (R2007) Standard Welding Procedure Specification (SWPS) for Gas Tungsten Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2), 1/8 through 1-1/2 inch Thick, ER70S-2, As-Welded or PWHT Condition, Primarily Pipe Applications – Site License (ANSI STANDARD)
14 AWS B2.2-1991 Standard for Brazing Procedure and Performance Qualification (ANSI STANDARD)
15 AWS B4.0:2007 Standard Methods for Mechanical Testing of Welds (ANSI STANDARD)
16 AWS B5.1:2003 Specification for the Qualification of Welding Inspectors (ANSI STANDARD)
17 AWS B5.2:2001Specification for the Qualification of Welding Inspector Specialists and Welding Inspector Assistants (ANSI STANDARD)
18 AWS B5.4:2005 Specification for the Qualification of Welder Test Facilities (ANSI STANDARD)
19 AWS B5.5:2000 Specification for the Qualification of Welding Educators (ANSI STANDARD)
20 AWS B5.9:2006 Specification for the Qualification of Welding Supervisors (ANSI STANDARD)
21 AWS B5.14:2002 Specification for the Qualification of Welding Sales Representatives (ANSI STANDARD)
22 AWS B5.15:2010Specification for the Qualification of Radiographic Interpreters (ANSI STANDARD)
23 AWS B5.16:2001 Specification for the Qualification of Welding Engineers (ANSI STANDARD)
24 AWS B5.17:2008Specification for the Qualification Of Welding Fabricators (ANSI STANDARD)
That's all available as per request
Thanks a lot
dear Achmad Nur Eddin
thanks a lot my friend for technical patronages.please give link for all B-D series.
I need all D series
You can see [URL="http://www.aws.org"]http://www.aws.org[/URL] to download AWS catalog, it have full standard
[QUOTE=Achmad Nur Eddin;78558]Fresh from the oven
[url]http://ifile.it/lvzk4tg/AWS%20B5.15-2010.pdf[/url][/QUOTE]
thanks a lot
D2D3D8D9.rar 11.46 MB
[url]http://ifile.it/3ef0wvk[/url]
[url]http://ifile.it/3ef0wvk/D2D3D8D9.rar[/url]
D14D11.rar 16.62 MB
[url]http://ifile.it/4lr9mvq[/url]
[url]http://ifile.it/4lr9mvq/D14D11.rar[/url]
AWS D1.6D1.6M-2007 Structural Welding Code - Stainless Steel.pdf 4.91 MB
[url]http://ifile.it/68uwrfo[/url]
[url]http://ifile.it/68uwrfo/AWS%20D1.6D1.6M-2007%20Structural%20Welding%20Code%20-%20Stainless%20Steel.pdf[/url]
AWS D14.5 - Spec. f Welding Presses Components 1997.pdf 7.11 MB
http:/ifile.it/bq4wg81
[url]http://ifile.it/bq4wg81/AWS%20D14.5%20-%20Spec.%20f%20Welding%20Presses%20Components%201997.pdf[/url]
AWS D3.6 Underwater Welding, Specification 1999.pdf 6.39 MB
[url]http://ifile.it/1v4ajym[/url]
[url]http://ifile.it/1v4ajym/AWS%20D3.6%20%20Underwater%20Welding%2C%20Specification%201999.pdf[/url]
this folder on 4shared contains a lot of files related to welding hope this contains some useful info
[url]http://www.4shared.com/dir/11040488/de20179d/sharing.html[/url]
baibur ----- please a password is required. thank you in advance and regards
Dear Achmad Nur Eddin
I need AWS C7.1 and if you have also AWS C7.3
Hello Achmad Nur Eddin. Would you help me please with AWS D1.5/D1.5M-2002 Bridge Welding Code?
As requested by Manahan Rudolf
AWS B2.1.1.205-2007 Standard WPS of SMW Carbon Steel 1-8 thru 1 1-2 in.Vertical Uphill & Vertical Uphill & PWHT.pdf 0.265 MB
[url]http://ifile.it/dbzhx53[/url]
[url]http://ifile.it/dbzhx53/AWS%20B2.1.1.205-2007%20Standard%20WPS%20of%20SMW%20Carbon%20Steel%201-8%20thru%201%201-2%20in.Vertical%20Uphill%20%20%26amp%3B%20Vertical%20Uphill%20%26amp%3B%20PWHT.pdf[/url]
AWS B2.1.1.206-2007 Standard WPS of SMW Carbon Steel 1-8 thru 1 1-2 in.Vertical Uphill & Vertical Downhill & PWHT.pdf 0.267 MB
[url]http://ifile.it/krdgjf1[/url]
[url]http://ifile.it/krdgjf1/AWS%20B2.1.1.206-2007%20Standard%20WPS%20of%20SMW%20Carbon%20Steel%201-8%20thru%201%201-2%20in.Vertical%20Uphill%20%20%26amp%3B%20Vertical%20Downhill%20%26amp%3B%20PWHT.pdf[/url]
[QUOTE=Rock&welding;87067]Hello Achmad Nur Eddin. Would you help me please with AWS D1.5/D1.5M-2002 Bridge Welding Code?[/QUOTE]
AWS D1.5D1.5M-2002 Bridge Welding Code.pdf 24.450 MB
[url]http://ifile.it/smgaxq6[/url]
[url]http://ifile.it/smgaxq6/AWS%20D1.5D1.5M-2002%20Bridge%20Welding%20Code.pdf[/url]
