hy guys i want petral...any links?
Printable View
Anyone have property modeling demo data for training Petrel. Please share with everyone
Hello everybody,
I´m trying to import a big data set from RMS project to Petrel, but it seems to be quite dificult, any help could be useful.
Hello Temr,
Please you have been of great help. I have been folowing ur thread. I sincerely appreciate it.
I will be also grateful if i can communicate with you one on one via email. Coz i really like the good work u are doing here. I am very new to petrel and i need to learn and know how to use it. I have tried several times to use it, but i couldnt. I will be very grateful if u can consider my request once again, my email address is [email]efeworu@yahoo.com[/email]
I am am new with PETREL. I have 2010.1 model of PETREL. I wan to build a geologic model of a particular reservoir from the scratch. Please what set of data do i need? Lets say i get these data, Hod do i convert them to ASCII format? Then finally, How do i input these data into Petrel?
I will be most grateful if Someone can help me with a step by step process. on these. my email address is [email]efeworu@yahoo.com[/email]
Thank you.
I dont have petrel
[QUOTE=burundi;180281]Hello Temr,
Thank you.[/QUOTE]
Thanks for you feedback, but now i am luck of time doing my direct responsibilities, sorry.
If you will follow the thread and will use data set i prepared i think that will help you
somebody know how to make a cross plot between seismic and log in petrel, for exemple, a seismic attribute and porosity log
dear burundi please tell us what base data you have. in geological modeling you need many data from many sources. you can create a model by some data but your model has uncertinetly!
Ok I am pondering should I learn Petrel for a simple 3D geological model simulation via Eclipse.
The model consists of:
A dome 3D anticline structure
With 5 diff. layers
What my team have done so far:
The crude way of doing this is via eclipse data file which is to have a square block says dimension of 50 by 50 by 80 in DX,DY and DZ and "cut" the block from the outside and the inside to get our "dome or cone" shape using NTG 0 keyword.
Obviously this is crude and only works for homogenous geo model and it is extremely difficult to populate the cell manually with different permeability and porosity consistent with geological layering.
So far we have done a 2D model which is fairly easy since we used the TOPS keyword which automatically set-up the correct layer permeability and porosity since it is inclined.
Now exporting this for 3D problem, do you guys reckon I can used Petrel in order to create this 3D model without seismic, petrophysical and other hard/soft data?
Thanks for the help and tips.
thanks very much sir, but i have a quiry regarding core date pertaining kx and Ky (PERMIBILITY) WHAT WE USE IN PETREL X OR Y OR AVERAGE?
[QUOTE=ÃÈæ ÇáÚÈÇÓ;186815]thanks very much sir, but i have a quiry regarding core date pertaining kx and Ky (PERMIBILITY) WHAT WE USE IN PETREL X OR Y OR AVERAGE?[/QUOTE]
If you have full data you better to model x, y directions separately, but since the permeability is one of the match parameters during history match i would advise you to average x and y directions
hello dear users. i need some information for Gaussian Random Function Simulation (GRFS) method. i see this method added in Petrel 2009 and see good result by using it :)
please help me for recognize GRFS method :)
