Hello everybody,
Could you share the following ASTM documents in the last revision (2016)?
A370 – 16
A351 – 16
A453 –16
A194 – 16
A694 – 16
A162 – 16
E18 – 16
Thanks in advance.
Printable View
Hello everybody,
A370 – 16
A351 – 16
A453 –16
A194 – 16
A694 – 16
A162 – 16
E18 – 16
Thanks in advance.
much appreciated.
Hi - Does anyone have ASTM E1007-14 available?
Thaniks -
David
E1007-14 Standard Test Method for Field Measurement of Tapping Machine Impact Sound Transmission Through Floor-Ceiling Assemblies and Associated Support Structures
Thanks so much! Absolutely appreciated. If you have E492, E966 and E1414 available, those would also be really helpful too.
Any one can share ASTM D1203-16 please ?
E492-09 Standard Test Method for Laboratory Measurement of Impact Sound Transmission Through Floor-Ceiling Assemblies Using the Tapping Machine
E966-10e1 Standard Guide for Field Measurements of Airborne Sound Insulation of Building Facades and Facade Elements
E1414E1414M-11ae1 Standard Test Method for Airborne Sound Attenuation Between Rooms Sharing a Common Ceiling Plenum
Mr. Thompson, thank you again!
David
Hi Marty,
If you happen to have ASTM STP-, Issue 1018 "Oil Dispersants: New Ecological Approaches" please share it.
Thank you,
ASTM - STP 1018 - Oil Dispersants; New Ecological Approaches
[url]http://www.4shared.com/office/sXfmje5Cba/ASTM_-_STP_1018_-_Oil_Dispersa.html[/url]
Dear marty.
Thank you very much for your contributions, are helpful.
please wanted to know if you have the Annexes to ASTM D1250 tables.
I appreciate your attention, best regards.
What you want are the API MPMS chapter 11 files. They are already available, use the search.
