Re: PVelite 2014 + ------ (Working x86 x64 windows 8.1)
[QUOTE=lgwsaw;301472]Fatal Error #6007
HASP HL error 7: The HASP HL key is no longer available.
Now what!!!????[/QUOTE]
Let's do different.
This is the message of error. Got it, but where did you stuck? In which step? Until when all things were OK? Are you trying to install in a PC or laptop? Did you install the Microsoft Loopback Adapter (in case of laptop)?
'Cause we have to follow strictly all steps described in that archive LAVteam.nfo. Otherwise you'll be lost.
word;press was suspended...please upload to another ...thanks in advance
Hey guys,
I'm about to record a video in order to explain all steps. The problem is: I'm not having time to do this.
Let's be patience.
Peace.
Hey guys,
Let's be patience.
Peace.
dear all,
i have downloaded pvelite2014. as per the installaion procedure, the ****** folder should have sp*****n.exe & k****n.exe. however, i could only find k******.exe in the ****** folder. due to this, i am unable to install pvelite. pls someone help!!!
dear all,
it's possible to install PV elite 2014 in windows 10? when i do this i have a msg error:
error 1904.module C:\program files (X86)\Intergraph CAS\PV ELITE
Dear All,
While running license.exe, I selected the option "Install & Remove" , but the option of "Install License Key" was not there. Instead, it gave onl two options of "Start the License Service & "Stop the License Service". Someone please help, how to get the "Install License Key" option on license.exe
Dear users,
If anyone tried it on windows 10 can you help me please? Problem is installing splm.
Thanks alot.
Could you install Splm ? Because my main problem is to install Splm. If so can you help me please ?
Greetings, after, doing everything as it says, I get this problem: (license.exe), choose 'Install and remove' option, choose 'Install License Key' option and paste copied license in the field, press OK. But then I get the message:"Invalid Key - not within installation period. So I get no license.
Anyone any dias?
Thanks in advance.
dear all,
can u post again the link.
Thank you
1 Attachment(s)
i m getting a error 1904 module splm installation completed but error showing after pv elite installation pls help me. i m attaching the image of the same[ATTACH]10010[/ATTACH]
Dear Friends,
I have downloaded pvelite 2018 from downloadly.ir but it only worked in windows 10 x64bit and did not installed in windows 8.1 x64 bit and windows 7 32bit.
If anybody installed in windows 8.1 and windows 7 and works perfect , please share your method and pc details.
