Re: Etap-16
[QUOTE=surgeArrester;346069]Yes there is not. If you using a usb key* original etap* there is no way unless you pirate it.
Sent from my iPad using Tapatalk[/QUOTE]
Yes using orginal etap 16.1
Sadly no ***** for etap 16.1 yet I believe? Only etap 16 is what i found and on the links provided by himmelstern (even though it says etap 16.1 on the site)
Re: Etap-16
that's true there is no solution for etap 16.1; even solution for 16.0 don't work on 16.1 version.
And files worked on 16.1 version* don't open at 16.0 version.
1 Attachment(s)
Re: Etap-16
[QUOTE=himmelstern;346094]that's true there is no solution for etap 16.1; even solution for 16.0 don't work on 16.1 version.
And files worked on 16.1 version* don't open at 16.0 version.[/QUOTE]
Yeah* I tried opening 16.1 files via 16.0 It doesn't work
This error pops out:
[ATTACH]10250[/ATTACH]
I wonder if there is a way to change this
the "Database version number" of 16.0 to make it think it is [B]30327[/B] instead of [B]30321[/B]. My theory is that 16.0 can still open 16.1 but there is just some blocking going on? Not sure.
For example version 12.6 files can be opened by version 12.5
Re: Etap-16
if cant download* this is the link for the full software with ********. [url]https://thepiratebay.org/*******/17808083/ETAP_16.0.0_x64[/url]
Re: Etap-16
I noticed that that version of etap 16.0 with ******** has an issue that when you are working* passed half an hour at edit mode don't do some changes any more* you must close and open again the application and continue editing.
when you export to dxf* the items of power system* that blocks are not scaled.
i also noticed this but i didnt know about the time* but i always restart it and its okay. and we also cant do load profile studies..
Re: Etap-16
[QUOTE=himmelstern;346390]I noticed that that version of etap 16.0 with ******** has an issue that when you are working* passed half an hour at edit mode don't do some changes any more* you must close and open again the application and continue editing.
when you export to dxf* the items of power system* that blocks are not scaled.[/QUOTE]
Everyone can't solve everything...lol
You need some specialist ;)
Re: Etap-16
[url]https://we.tl/y6jkfgfKZN[/url]
[url]https://we.tl/8jUApYJhMQ[/url]
[url]https://we.tl/O0tiPatzjc[/url]
Try to download with Firefox and Downthemall extension
Re: Etap-16
[QUOTE=cadguy;346415]Everyone can't solve everything...lol
You need some specialist ;)[/QUOTE]
and............... Are you the specialist Mr Cadguy? ....
Re: Etap-16
I believe these solutions for 1410 and 1600 need to revised.
Does anyone here has a solution for ETAP 12.6.5 or anyone have experience with activate 12.6.5 by using 12.6 solution.
Thanks.
Re: Etap-16
Could someone provide ETAP 16.1 Source Link please.
Re: Etap-16
Guys please check the link that i found*
