Hi All , i urgently need help wit some electrical design. its a 2-storey containing 7 apartments. one main panel board serving the seven consumer units, a backup generator set for the whole building, manual changeover switch. wat wiring design can ensure the meter does not read when you change supply to the generator, that is i do not want to do the double wiring bcos of cost.
Pls gurus, help, the proj is ongoing
regards,
kebian
[QUOTE=Kebian;165297]Hi All , i urgently need help wit some electrical design. its a 2-storey containing 7 apartments. one main panel board serving the seven consumer units, a backup generator set for the whole building, manual changeover switch. wat wiring design can ensure the meter does not read when you change supply to the generator, that is i do not want to do the double wiring bcos of cost.
regards,
kebian[/QUOTE]
Dear My friend kebian,
isn't it easy stuff ?, usually i just made a scratch design with etap and then I compare to standard, finally I call my friend which brand is high reliability with optimum budget..
how is it ?
[QUOTE=Rudi Tua;169915]Dear My friend kebian,
how is it ?[/QUOTE]
but eventhough its easy, its time consuming ... sometime mind freaking
[QUOTE=Kebian;162431]hi All,
i am try'n to launch etap for the first time but can get thru the etap license path selection edit box- its requesting for the IP address of the etap license server, can someone pls get me that. swami says i shd install etap6 , apply peta6 ******** and use the serial, then etap7 will work. someone pls upload n give me the links to download etap6, pls remember to add the peta 6 ******** n the serial
regards,
kebian[/QUOTE]
Kebian,
If you follow all the step, i think it is impossible you failed. except you got 64bit computer .... you have to install with other step. but if you got 32bit ... dont mis a thing on the installation step.
Oh ya ... once or twice I fail to install it, with this situatiion.
1. The windows files is broken by virus ... so some dll files on windows is broken so that etap files can not work together with windows, in this matter, I reformat my notebook.
2. 3 days ago I helped my friend to install on notebook and fails ... after seeking, I found that some dll files on windows is broken by RECYCLER virus ... so I suggest him to reformat it ... now I am waiting for his action.
First of all, you must confirm your computer is 32bit, then follow the installation step, otherwise, use/install virtual machine on your 64bit computer, then install windows 32bit on client computer during running virtual machine software then follow with install etap 32bit.
hope this would help you.
One more thing, in order to install etap 7.0, you dont need to install etap 6.0 first,
just follow the exact step of etap 6.0 installation step, it should work.
hi,
Is any body help me out to get the License code of etap v 7. It is installed fully on my laptop, but when i start the application it demands the license code. It requires hardware key. Is there any other method to get the key... please help me out...
Thanks in adance.
I tested on my win XP. it is working. Just follow the instructions provided.
[QUOTE=sili_bhoot;171662]hi,
Thanks in adance.[/QUOTE]
Dear Mr bhoot,
I think that your computer may be 64bit system, please check the properties. If it is true, then you must install it using Virtual Machine computer ,
any one can share E tap full version which is match with window 7 ,64 bit
or Automation studio for window 7 full version pls share with us
is there any chance to install etap7 on a 64 bit operating system?
[QUOTE=LOST;173557]is there any chance to install etap7 on a 64 bit operating system?
Regards[/QUOTE]
Hi brother LOST
I've spent my time to search those things, but still no progress.
But my suggestion is use virtual machine software (like "VMware) in your 64bit computer to install 32bit windows, then you can install ETAP 32bit.
it works, I've tried twice.
Re: Etap 7
Hi guest,
I have finished download ETAP 7.0 in [url]www.4share.com[/url] but it still in RAR file & I couldn't extract that RAR because it need password UNRAR.
Please help me to get that password. I am very need it
Thank u for your help
Re: Etap 7
