I share the PF 15.1.7 X86. The M.edicine works.
[URL="http://www.4shared.com/file/oyzkgj7aba/PF-1517_x86.html"]http://www.4shared.com/file/oyzkgj7aba/PF-1517_x86.html[/URL]
[ATTACH]5614[/ATTACH]
Printable View
[QUOTE=vlady34;292161]I share the PF 15.1.7 X86. The M.edicine works.
[ATTACH]5614[/ATTACH][/QUOTE]
Dear Vlady thanks ..
Anyway, could you share digsilent 15.1.7 for windows 64 bit ?
How to apply med for 15.1.7 : When I try, receive the message "digadm.dll - file not found or file access error"
Check if you are trying it over 32 bit. For 64 bit installation this one will not work. However 32 bit installation on 64 bit system will work.
Check if your digadm.dll not read-only format. Try to run the pat-cher as administrator.
[QUOTE=cadguy;292255]Check if you are trying it over 32 bit. For 64 bit installation this one will not work. However 32 bit installation on 64 bit system will work.
Check if your digadm.dll not read-only format. Try to run the pat-cher as administrator.[/QUOTE]
Thanks cadguy, it works on my 64 bit ..
However, how to add relay libraries from this source : [url]https://www.sendspace.com/file/j0rofh[/url] to digsilent 15.1.7
[QUOTE=sophaholic;292275]Thanks cadguy, it works on my 64 bit ..
However, how to add relay libraries from this source : [url]https://www.sendspace.com/file/j0rofh[/url] to digsilent 15.1.7[/QUOTE]
It decompresses anywhere, then the library that you want to project where it will be used and the parameters are input relay is imported.
[QUOTE=vlady34;292276]It decompresses anywhere, then the library that you want to project where it will be used and the parameters are input relay is imported.[/QUOTE]
So, can we put like this :
C:\Program Files (x86) \DigSILENT \ PowerFactory 15.1 ?
At night I will upload a short video to see how the libraries are used.
Book PF Applications, maybe you have it already...
http://novafile.com/03wpveyce1o9[/URL]
[QUOTE=vlady34;292312]At night I will upload a short video to see how the libraries are used.[/QUOTE]
Where is the video vlady34 ?
Can anyone please upload the PF and ********?
THanks.
