Thank You Sir, for this nice Share
Printable View
Nice picture
I am a chemical engineering student and my final project is about a processing gas plant. It is a DDP (Dew Point Plant). In the end of the process, there is a stabilization tower that separates two fractions, one light having C1 and C2 and other heavy with C3, C4, C5+. .
The idea is to separate the C3 from the heavy stream to reuse in the refrigeration system (simple refrigeration by propane) of the plant. Today the C3 for refill the refrigeration system is bought, so we want make itself sustainable in refrigerant fluid with this adaptation. .
Which would be a good layout and equipments to do that? Does someone have any tip?
Thank You
Thiago
thanks you boss
Dear Mohamed,
Nice view of gas processing.
1- Acid gas removal unit(AGU) and dehydration unit: PSA needs to be replaced with TSA (temperature swing adsorption)
2- Acid gas removal unit should be done with membrane.
3- mercaptan removal unit or MRU
Thanks again
Hi,
Can Some send me Typical P&ID for Gas Dehydration system.
My Id: [email]deeps_jagtiani@yahoo.co.in[/email]
Nice one. However, where we have to install the compression facility.
thank you,..
thank u
Salam,
Have you iso 6976 please
thank you
PS: Good Ramadhan for all Muslims
Ait-Abdallah
