Can someone publish here or share anywhere the activation codes for version 11 and 12 (maybe even 12.5 if there is one)...
Yet, unfortunately personally I have lot of troubles with missing LPT
Printable View
[QUOTE=JARS2011;207729]I have a ETAP 11.1.O FULL
Regards[ATTACH=CONFIG]2636[/ATTACH][ATTACH=CONFIG]2637[/ATTACH][/QUOTE]
i really wonder why our friends here tells us that they have a full version of Etap 11 and don't want to upload it for the others i tired from searching about ----- and can't find it
[QUOTE=garrison2711;261165]Can someone publish here or share anywhere the activation codes for version 11 and 12 (maybe even 12.5 if there is one)...
Yet, unfortunately personally I have lot of troubles with missing LPT[/QUOTE]
I also wonder why others are always asking for etap v11 activation codes when in fact if they have just read sa topic in this forum with attention i guess they could have found the answer. Please try to look in the forum for code.
For the emulator, you can install virtual lpt if the port doesnt work, try to change resources settings.
Sent from my iPhone using Tapatalk
Hello, how to calculate short circuit current(with ETAP) after current transformer in the configuration shown in the picture? I included and picture where it's shown how I reproduced it in ETAP but I would need SC exactly where is that T. Could somebody help me with bigger experience working in ETAP?
[ATTACH=CONFIG]4591[/ATTACH]
[ATTACH=CONFIG]4592[/ATTACH]
Double. Sorry.
[QUOTE=hb5;261259]Hello, how to calculate short circuit current(with ETAP) after current transformer in the configuration shown in the picture? I included and picture where it's shown how I reproduced it in ETAP but I would need SC exactly where is that T. Could somebody help me with bigger experience working in ETAP?
[ATTACH=CONFIG]4592[/ATTACH][/QUOTE]
For me you cant, this is a split wye configuration for cap banks. What i did is that i modelled this using pscad. It Is difficult using etap. The only ct you can model is the line ct not the ct between neutrals.
Thank you for your answer! Could you show me how to do it in PSCAD? I haven't worked with that software so far.
please help me.
my etap 11 dont recognize licence manager
please help me.
[QUOTE=tak2750;261594]please help me.
my etap 11 dont recognize licence manager[/QUOTE]
i add the ecp port and now it is working
[QUOTE=hb5;261587]Thank you for your answer! Could you show me how to do it in PSCAD? I haven't worked with that software so far.[/QUOTE]
I will try but i have done it in the past.
[QUOTE=tak2750;261602]i add the ecp port and now it is working[/QUOTE]
Hello, Thansk a lot FX007, i want share this links, i have try to test of procedure of FX007, i had a problem, it did not working, my problem was the port printer configuration, already i fix it.
I test the installation in these SO. and these are working.
Windows 7 32 Bits
Windows 7 64 Bits
The ---- do not working in Etap Ver 11.1.1 SP, but it Working in Version 11.1.1 English, i shared this last version, the link are:
this have no password
The link is the next, only add "https : //"
etapsupport.box.com/shared/y18ed1jy8ntbdfinsuzm/1/429583330/3508229520/1#/s/y18ed1jy8ntbdfinsuzm/1/429583330/3508229520/1
Could someone take photos of the installation process (especially as to how to configure ECP port) and post them here please? Thanks in advance.
The settings in lpt port sometimes varies in some PCs. The important thing to note is that this setting does not conflict with the existing I/O settings that are already used.
Sent from my GT-I9082 using Tapatalk
[QUOTE=surgeArrester;263153]The settings in lpt port sometimes varies in some PCs. The important thing to note is that this setting does not conflict with the existing I/O settings that are already used.
Sent from my GT-I9082 using Tapatalk[/QUOTE]
Could you describe the procedure of LPT port configuration in computers without such ports? My laptop has no LPT port, as happens in most cases of new machines.
Have you tried to read the other posts here?
It seems the procedure is already given by previous posts.
Go to the device manager and add it.
[QUOTE=surgeArrester;263164]Have you tried to read the other posts here?
There is no COM/Ports on my device manager option.. Could you please advice me on that surge arrester?
Thanks in advance..
i'm sorry.. i don't know where to start. But you have to follow the previous post to know the instruction. This is to force you to read previous posts.
I'll try to start it from scratch now.. Hope that it will work.. :)
