can you please apload asme viii div 1
Printable View
Hi
Where can I find API 618 5th Edition
Cheers
can anybody share the API RP1133 2005 ?
Guidelines for Onshore Hydrocarbon Pipelines Affecting High Consequence Floodplains
I need it very urgently
I am working on a few data points where I need to calculate the corrected API (@ 60F) from an observed API which was taken at a different temperature for crude oil. I also need to calcualte corrected volume as well for which I believe I understand I need the VCF (Volume Correction Factors).
I understand that "Adjunct to D1250 Petroleum Measurement Tables – Volume I" contains Table 5A: Generalized Crude Oils, Correction of Observed API Gravity to API Gravity at 60°F and Table 6A: Generalized Crude Oils, Correction of Volume to 60°F Against API Gravity.
I also understand that "Adjunct to D1250 Petroleum Measurement Tables – Volume X" contains Background, Development, and Computer Documentation and that Volume X actually has the algorithms and equations published for calculating and approximating all of the tables published in the 12 volume Adjunct set.
I don't know how many pages there are to Tables 5A and 6A in Volume 1 but that is what I believe I need. Even better would be the algorithms/equations that generate these particular tables for which I understand is published in Volume 10.
Can someone help me with this??
I only need this data for a one time set of calculations..
Thanks to whoever can help me with this!!
Greg
[url]http://depositfiles.com/files/xp1o1uzuu[/url]
[QUOTE=ghartman;94622]I am working on a few data points where I need to calculate the corrected API (@ 60F) from an observed API which was taken at a different temperature for crude oil. I also need to calcualte corrected volume as well for which I believe I understand I need the VCF (Volume Correction Factors).
Greg[/QUOTE]
I upload both Vol I & II for your convenience
API MPMS 11.1 VOL I 1st Ed 1987.pdf 27.9 MB
Chapter 11.1 Vol I 1st Ed 1987 or API STANDARD 2540 / IP200 / ANSI ASTM D 1250
TABLE 5A - Generalized Crude Oils and JP-4 Correction of Observed API Gravity to API Gravity at 60°F
TABLE 6A - Generalized Crude Oils and JP-4 Correction of Volume to 60°F Against API Gravity at 60°F
[url]http://ifile.it/eqia0w3[/url]
[url]http://ifile.it/eqia0w3/API%20MPMS%2011.1%20VOL%20I%201st%20Ed%201987.pdf[/url]
API MPMS 11.1 VOL II 1st Ed 1987.pdf 25.217 MB
Chapter 11.1 Vol II 1st Ed 1987 or API STANDARD 2540 / IP200 / ANSI ASTM D 1250
TABLE 5B-Generalized Products Correction of Observed API Gravity to API Gravity at 60°F
TABLE 6B-Generalized Products Correction of Volume to 60°F Against API Gravity at 60°F
[url]http://ifile.it/ybfz7l6[/url]
[url]http://ifile.it/ybfz7l6/API%20MPMS%2011.1%20VOL%20II%201st%20Ed%201987.pdf[/url]
[QUOTE=kircon;94932][url]http://depositfiles.com/files/xp1o1uzuu[/url][/QUOTE]
Thank you for API 1133
Thank you so much Achmad!!
looking for API MPMS Chapter 11.5
hi i really need:
API 2552
ISO 7507-1
IP 202 Part II Section 2
Hi
[url]http://rapidshare.com/files/383057127/API_STD_2552_R_2006_.pdf.html[/url]
[url]http://rapidshare.com/files/383057608/API_STD_2554.pdf.html[/url]
hi aragorn
thank you very much.
