ISO Collection 172/300:ISO TC 219-Floor coverings
full list:
ISO 1763:1986 Carpets -- Determination of number of tufts and/or loops per unit length and per unit area
ISO 1765:1986 Machine-made textile floor coverings -- Determination of thickness
ISO 1766:1999 Textile floor coverings -- Determination of thickness of pile above the substrate
ISO 1957:2000 Machine-made textile floor coverings -- Selection and cutting of specimens for physical tests
ISO 2094:1999 Textile floor coverings -- Determination of thickness loss under dynamic loading
ISO 2424:2007 Textile floor coverings -- Vocabulary
ISO 2549:1972 Textile floor coverings -- Hand-knotted carpets -- Determination of tuft leg length above the woven ground
ISO 2549:1972/Cor 1:1990 Textile floor coverings -- Hand-knotted carpets -- Determination of tuft leg length above the woven ground
ISO 2550:1972 Textile floor coverings -- Hand-made carpets -- Determination of types of knots
ISO 2551:1981 Machine-made textile floor coverings -- Determination of dimensional changes due to the effects of varied water and heat conditions
ISO 3018:1974 Textile floor coverings -- Rectangular textile floor coverings -- Determination of dimensions
ISO 3415:1986 Textile floor coverings -- Determination of thickness loss after brief* moderate static loading
ISO 3416:1986 Textile floor coverings -- Determination of thickness loss after prolonged* heavy static loading
ISO 4918:2016 Resilient* textile and laminate floor coverings -- Castor chair test
ISO 4919:2012 Carpets -- Determination of tuft withdrawal force
ISO 5086:1977 Textile floor coverings -- Hand-knotted carpets -- Sampling and selection of areas of test
ISO 6347:2017 Textile floor coverings -- Consumer information
ISO 6356:2012 Textile and laminate floor coverings -- Assessment of static electrical propensity -- Walking test
ISO 6925:1982 Textile floor coverings -- Burning behaviour -- Tablet test at ambient temperature
ISO 8543:1998 Textile floor coverings -- Methods for determination of mass
ISO 9405:2015 Textile floor coverings -- Assessment of changes in appearance
ISO 10361:2015 Textile floor coverings -- Production of changes in appearance by means of Vettermann drum and hexapod tumbler tester
ISO 10575:2012 Resilient floor coverings -- Specification for rubber sheet floor coverings with backing
ISO 10577:2012 Resilient floor coverings -- Specification for rubber sheet floor coverings without backing
ISO 10580:2010 Resilient* textile and laminate floor coverings -- Test method for volatile organic compound (VOC) emissions
ISO 10581:2011 Resilient floor coverings -- Homogeneous poly(vinyl chloride) floor covering -- Specifications
ISO 10582:2010 Resilient floor coverings -- Heterogeneous poly(vinyl chloride) floor coverings -- Specification
ISO 10595:2010 Resilient floor coverings -- Semi-flexible/vinylcomposition (VCT) poly(vinyl chloride) floor tiles -- Specification
ISO 10833:2017 Textile floor coverings -- Determination of resistance to damage at cut edges using the modified Vettermann drum test
ISO 10834:1992 Textile floor coverings -- Non-destructive measurement of pile thickness above the backing -- WRONZ gauge method
ISO 10874:2009 Resilient* textile and laminate floor coverings -- Classification
ISO 10965:2011 Textile floor coverings -- Determination of electrical resistance
ISO 11377:1997 Textile floor coverings -- Floor soiling -- Test site set-up and soiling evaluation
ISO 11378-1:2000 Textile floor coverings -- Laboratory soiling tests -- Part 1: Kappasoil test
ISO 11378-2:2001 Textile floor coverings -- Laboratory soiling tests -- Part 2: Drum test
ISO 11378-2:2001/Amd 1:2017 Textile floor coverings -- Laboratory soiling tests -- Part 2: Drum test
ISO 11379:2009 Textile floor coverings -- Laboratory cleaning procedure using spray extraction
ISO 11638:2012 Resilient floor coverings -- Heterogeneous poly(vinyl chloride) flooring on foam -- Specification
ISO 11857:1999 Textile floor coverings -- Determination of resistance to delamination
ISO 11858:1999 Textile floor coverings -- Determination of friability of attached foams
ISO 11859:1999 Textile floor coverings -- Pure wool* hand-knotted pile carpets -- Specification
ISO 11860:1999 Textile floor coverings -- Jute carpet backing fabric -- Specification
ISO 11861:1999 Textile floor coverings -- Coir mats -- Types and specification
ISO 12951:2015 Textile floor coverings -- Determination of mass loss* fibre bind and stair nosing appearance change using the Lisson Tretrad machine
ISO 13746:2000 Textile floor coverings -- Guidelines for installation and use on stairs
ISO 13750:2000 Textile floor coverings -- Determination of resistance to staining by acid food colours
ISO 14486:2012 Laminate floor coverings -- Specification
ISO 16581:2014 Resilient and laminate floor coverings -- Determination of the effect of simulated movement of a furniture leg
ISO 16905:2015 Resilient floor coverings -- Specification for rubber floor covering -- Tile/Plank
ISO 16906:2015 Resilient floor coverings -- Determination of seam strength
ISO 17504:1999 Textile floor coverings -- Determination of wool fibre integrity using an abrasion machine
ISO/PAS 18167:2014 Textile floor coverings -- Installation practices -- General
ISO 18168:2015 Textile floor coverings -- Colour fastness to shampooing
ISO 20251:2016 Textile floor coverings -- Water impermeability test
ISO 20253:2016 Textile floor coverings -- Blade test -- Flocked textile floor covering
ISO 20326:2016 Resilient floor coverings -- Specification for floor panels/assembly for loose laying
ISO 23996:2007 Resilient floor coverings -- Determination of density
ISO 23997:2007 Resilient floor coverings -- Determination of mass per unit area
ISO 23999:2008 Resilient floor coverings -- Determination of dimensional stability and curling after exposure to heat
ISO 24011:2009 Resilient floor coverings -- Specification for plain and decorative linoleum
ISO 24334:2014 Laminate floor coverings -- Determination of locking strength for mechanically assembled panels
ISO 24335:2006 Laminate floor coverings -- Determination of impact resistance
ISO 24336:2005 Laminate floor coverings -- Determination of thickness swelling after partial immersion in water
ISO 24337:2006 Laminate floor coverings -- Determination of geometrical characteristics
ISO 24338:2014 Laminate floor coverings -- Determination of abrasion resistance
ISO 24339:2006 Laminate and textile floor coverings -- Determination of dimensional variations after exposure to humid and dry climate conditions
ISO 24340:2006 Resilient floor coverings -- Determination of thickness of layers
ISO 24341:2006 Resilient and textile floor coverings -- Determination of length* width and straightness of sheet
ISO 24342:2007 Resilient and textile floor-coverings -- Determination of side length* edge straightness and squareness of tiles
ISO 24342:2007/Amd 1:2012 Resilient and textile floor-coverings -- Determination of side length* edge straightness and squareness of tiles
ISO 24343-1:2007 Resilient and laminate floor coverings -- Determination of indentation and residual indentation -- Part 1: Residual indentation
ISO 24343-2:2011 Resilient and laminate floor coverings -- Determination of indentation and residual indentation -- Part 2: Short-term residual indentation of resilient floor covering
ISO 24343-3:2011 Resilient and laminate floor coverings -- Determination of indentation and residual indentation -- Part 3: Indentation of resilient semi-flexible/vinyl composition tiles
ISO 24344:2008 Resilient floor coverings -- Determination of flexibility and deflection
ISO 24345:2006 Resilient floor coverings -- Determination of peel resistance
ISO 24346:2006 Resilient floor coverings -- Determination of overall thickness
ISO 25620:2008 Laminate floor coverings -- Determination of long-side friction for mechanically assembled panels
ISO 26985:2008 Resilient floor coverings -- Identification of linoleum and determination of cement content and ash residue
ISO 26986:2010 Resilient floor coverings -- Expanded (cushioned) poly(vinyl chloride) floor covering -- Specification
ISO 26987:2008 Resilient floor coverings -- Determination of staining and resistance to chemicals
missing are:
[url]http://www.mediafire.com/file/n60ns3cx1jzlyxw/ISO_172-Floor_Coverings_%2815-09-2017%29.rar[/url]
