1 Attachment(s)
SKM POWER TOOLS - 7.0.2.4 (Working in Windows 8, 64 Bits)
Hi Engineering Community!!!!
I have running SKM POWER TOOLS - 7.0.2.4 in Windows 8 64 Bits. I am not using Virtual Machine. The successful steps are:
1) Download the installation files and ****** from these links
[url=http://www.4shared.com/rar/maw_r7WPce/SKM_POWER_TOOLS_-_7024.html]SKM POWER TOOLS - 7.0.2.4 - Download - 4shared[/url] Installation Files
[url=http://4server.info/download/4shared.com/get/pwDBAtEUce/SKM_PTW.html]SKM PTW | 4server.info[/url] ******
2) Install SKM PTW 7.0.2.4.
3) Copy the files (ckInfo.exe & CrypKey Site Key Generator.ckInfo) and Paste on C:/……../bin/
4) Run PTW32 as administrator and install with softkeys ... later you will see your SITE CODE. Later we will use the SIDE CODE
5) Run ckinfo.exe. as administrator
6) Select CrypKey Site Key Generator.ckInfo and Open it
7) Type your SITE CODE and then ENTER... This script will generate your SITE KEY
8) Copy the Encrypting Key and Paste in your SITE KEY
9) Click Update. When you click on update you will see these windows. See the picture attached.
[ATTACH]5474[/ATTACH]
10) Open the "PTW Registry Cleanup UtilIty" and select the option " ALL settings in the registry for PTW" then click OK.
After you clean the registry you can use the SKM PTW in windows 8 64 Bits. :) Have fun and share with more people!
POST DATA: I need the ****** for ETAP 12.6 Who can help me? In the same folder of 4shared you can download more information like ETAP 12.6 (installation files) and more electrical documents :) check it
Re: SKM POWER TOOLS - 7.0.2.4 (Working in Windows 8, 64 Bits)
Thank you friend - it work for me now.
Great ... Let me know if you find the ****** for ETAP 12.6 :)
Please, not found ******......
Vladimir check again the folders :)
[QUOTE=vlady34;286266]Please, not found ******......[/QUOTE]
maybe it was deleted by your AV. Please check your AV (detected items or deleted items). I suggest that instead or uploading rar or zip files, it is may better to be in ISO format.. If you mount it on virtual drive, the AV can't delete them.
Good morning, what happens the ****** does not come in the rar file, so my AV did not eliminate it. I'll check the folder again. Thank You .....
PD: Not if you have different name but I still find it ....
I made a double check today and all information needed is in the folder. :)
It seems that the ****** is not in the folder. Would it be possible to post to ****** again.
Thanks,
[QUOTE=EE_Newbie;286304]It seems that the ****** is not in the folder. Would it be possible to post to ****** again.
Thanks,[/QUOTE]
Check again the ****** is inside :)
Hello raz, I downloaded the files twice and have searched the folder you placed the link but can not find the ******. In reviewing the * .rar is only the installer but not the files that you mention in your post. Maybe can tell us how to make the functional SKM. Thank You.
I download several times as well, but none have ******. I even disable AV and no ******.
