Hongxing experts teach you how to operate hammer crusher
[url=http://www.hxjqmining.com/pro/hammer_mill.html]Hammer crusher[/url] operation and inspection points.
(1) to get in touch with the machine, the next step before open parking, correct operation according to the sequence of open parking.
(2) to empty start, attention should be a crushing cavity material unloaded after shutdown.
(3) all the anchor bolts, liner bolts often check the equipment, there are no loose, if loose, should be timely fastening.
(4) often check the hammerhead, lining board and so easy to wear the use of easy wearing parts, if found, should be timely treatment.
(5) to watch the lubrication conditions, to maintain a good state of lubrication system. Rotor bearing temperature should be kept below 60 ℃, highest do not exceed 70 ℃, such as the discovery of over-temperature should identify the reasons, timely take measures to eliminate the.
(6) maintain uniform feeding, and pay attention not to make the metal debris feeding.
(7) to check the material particle size is in accordance with the quality requirements, if not, should be replaced or adjusted grate grate bracket height.
Unique performance and advantages of this crusher makes it not only able to crush stone materials, but able to manufacture sand to some way, thus realizing the perfect combination and anti friction and fine particle discharging, so that it is one of the ideal [url=http://www.hxjqmining.com/pro/impact_crusher.html]crushing machine[/url]s in large stone plant and mining crushing plants.
This series cone crusher is hongxingly used in the secondary or third crushing stage and has obvious crushing effect especially when used for crushing medium hard materials. This crushing plant has big crushing ratio and processing quantity, low operational cost, high working efficiency and convenient adjustment. It has been proved that the highly efficient cone crusher is well received among the customers with excellent performance, reliable quality and high cost performance and is the ideal substitute product for traditional cone crusher.
hammer mill: [url]http://www.plantcrushing.com/pros/hammer-crusher.html[/url]
