Plz help me for ASTM A-36 & ASTM 1-242 Standard. if some have kindly send me the link.
Printable View
[B]Here is your request[/B]
[I]I hope I helped.[/I]
[ATTACH]3134[/ATTACH][QUOTE=burhan99;221900]Plz help me for ASTM A-36 & ASTM 1-242 Standard. if some have kindly send me the link.[/QUOTE]
[COLOR="#0000FF"][SIZE=6][B]ASTM New Documents ....[/B][/SIZE][/COLOR]
Document Number Date Title
[B][COLOR="#0000FF"]internationalstandard2012@gmail.com[/COLOR][/B]
please.I hope this help you
Dear sir
i need ASTM D-2270 codes i need my email id is nizami777"gmail.com
awaites your reply
regards.
hello, I need
ASTM D1210 Edition 2010
ASTM D281 Edition 2012
ASTM D2369 Edition 2011
ASTM D3359 Edition 2010
ASTM D1640 Edition 2009
who can help me?
so many thanks
Dear All,
I need ASTM B456 - 03 Standard Specification for Electrodeposited ... or Copper Coating on MS Rod Standard
Thanks & Regards,
Khalid
Can anyone tell me where i can downloan ASTM standard? thanks!
