need ASTM E883-11, ASTM E3-11,ASTM E407-07,ASTM A604-07,ASTM E340-00, ASTM E381-01
I need a copy of ASTM E883-11, ASTM E3-11,ASTM E407-07,ASTM A604-07,ASTM E340-00, ASTM E381-01
Appreciate if you can forward a copy if you have it.
Many thanks in advance.
2 Attachment(s)
Re: need ASTM E883-11, ASTM E3-11,ASTM E407-07,ASTM A604-07,ASTM E340-00, ASTM E381-0
Only E340-00 & E381-01, others later version
1 Attachment(s)
current audit standards [ATTACH]3138[/ATTACH]
[COLOR="#0000FF"][SIZE=6][B]ASTM New Documents ....[/B][/SIZE][/COLOR]
Document Number Date Title
[B][COLOR="#0000FF"]internationalstandard2012@gmail.com[/COLOR][/B]
Dear Marianna,
Can you please repost ASTM E3
Does anyone have ASTM E407 - 07(2015)e1 ?
1 Attachment(s)
E3-11 Standard Guide for Preparation of Metallographic Specimens
1 Attachment(s)
E407-07(2015)e1 Standard Practice for Microetching Metals and Alloys
Re: need ASTM E883-11* ASTM E3-11*ASTM E407-07*ASTM A604-07*ASTM E340-00* ASTM E381-0
