PFD - Process Flow Diagram - Example
A Process Flow Diagram - PFD - (or System Flow Diagram - SFD) shows [B]relationships[/B] between major components in a system. A PFD also tabulate process design values for the components in different operating modes, typical minimum, normal and maximum values. A PFD does not show minor components, the piping systems, piping ratings and designations.
A Process Flow Diagram - PFD - should include:
[LIST][*]process piping[*]major equipment symbols, names and identification numbers[*]control, valves and valves that affect operation of the system[*]interconnection with other systems[*]major bypass and recirculation lines[*]system ratings and operational values as minimum, normal and maximum flow, temperature and pressure[*]composition of fluids[/LIST]
A Process Flow Diagrams - PFD - should not include:
[LIST][*]pipe classes[*]pipe line numbers[*]minor bypass lines[*]isolation and shutoff valves[*]maintenance vents and drains[*]relief and safety valves[*]code class information[/LIST]
Re: PFD - Process Flow Diagram - Example
my freind how can i down load this could you guide me or email it to me address [email]engrfraz@yahoo.com[/email] , i would highly appreciate it
