Dose any one have the meterials about how to predict the productivity of muli-fracture horizontal well?
Or some meterials about how to simulate the muli-fracture horizontal well?
Printable View
[url]http://www.egpet.net/vb/showthread.php?48722-Tight-Gas-Reservoir-Simulation[/url]
Refer to Joshi's book "Horizontal Well Technology", page 149 for a great theoretical discussion about it.
FYI - I have developed a set of relationships that allows for coarse scale simulation of hydraulic fractures in horizontal and vertical wells, including scenarios with more than one fracture in a grid block in a method that requires no grid modifications. It handles Fcd's from 0.1 to 100 very well
I plan to publish in a paper one day when I get around to it... so stay tuned... no need for logarithmically spaced LGR's! :-)
[QUOTE=vinomarky;178778]FYI - I have developed a set of relationships that allows for coarse scale simulation of hydraulic fractures in horizontal and vertical wells, including scenarios with more than one fracture in a grid block in a method that requires no grid modifications. It handles Fcd's from 0.1 to 100 very well
I plan to publish in a paper one day when I get around to it... so stay tuned... no need for logarithmically spaced LGR's! :-)[/QUOTE]
I think that's what already performed by Petrel once you set up hydraulic fractures in the completion .... correct me if I am wrong !!!
You are partialy correct. Petrel does indeed have the feature, but
- it does not match type curves at all
- it modifies blocks outside of volume affected by frac and
- it is a proprietary method requiring a license to access
My method matches type curves, modifies only blocks affected and can easily be implemented in excel to give you the code to put in your schedule section :-)
