Carbon, Alloy and Stainless Steel Pipes- ASME/ANSI B36.10/19
[SIZE=3]Covers the standardization of dimensions of welded and seamless wrought steel pipe for high and low temperatures and pressures.
[/SIZE]
[SIZE=3] [/SIZE][SIZE=3]The steel pipe data chart below can be used to find pipe sizes, diameters, wall thickness, working pressures and more The chart is based on ASME/ANSI B 36.10 Welded and Seamless Wrought Steel Pipe and ASME/ANSI B36.19 Stainless Steel Pipe.[/SIZE]
[SIZE=3] [/SIZE][SIZE=3]Regardless of schedule number, pipes of a particular size all have the same outside diameter (not withstanding manufacturing tolerances). As the schedule number increases, the wall thickness increases, and the actual bore is reduced. For example:
[/SIZE]
[SIZE=3] [/SIZE]
[LIST][*][SIZE=3]A [I]4 inches (100 mm) [/I]Schedule 40 pipe has an outside diameter of[I] 4.500 inches (114.30 mm)[/I], a wall thickness of [I]0.237 inches (6.02 mm)[/I], giving a bore of [I]4.026 inches (102.26 mm)[/I][/SIZE][*][SIZE=3]A [I]4 inches (100 mm)[/I] Schedule 80 pipe has an outside diameter of [I]4.500 inches ( 114.30 mm)[/I], a wall thickness of [I]0.337 inches (8.56 mm)[/I], giving a bore of [I]3.826 inches (97.18 mm)[/I].[/SIZE][/LIST]
Re: Carbon, Alloy and Stainless Steel Pipes- ASME/ANSI B36.10/19
Dear cpchonburi,
Please upload the link again.
Thanks & Regards,
Amit
